Originally posted by Medium FormatPro A fair portion of my work is "dealing somewhat" in fashion photography - and working directly with some of the leaders in that field; in places like NYC, Paris, Milan, etc... I'm presently negotiating a deal with Buckle - and also already do contract work with eleven other clothing type lines.
I would even be willing to risk being an early adopter of the newer version of the K-5 -and then even use it in items like the above mentioned fashion pics; and even as a type of back-up camera for weddings, main line camera for senior portraits, even portfolios.
I've had very little need to actually "edit out" the effects of not having the AA. Although also noting it is not a complicated procedure under CSxx (whatever the version is - either or without plug-ins). But I also do not remember off hand IF the feature to edit such is actually included (or bundled) with items like the included SilkyPics (even as an option) or also if it's available on items like less costly versions of CSxx.
To conclude with my perspective... Yes I'll be upgrading - mostly because my budget would allow it. But I'll also be keeping the current K-5 as well. The only literal consideration is IF someone does have the post-processing that allows the AA to be adapted for. Btw, I also know a number of pro's who rarely even touch digital post-processing; even so far as having someone do it for them if that need ever comes about
Thanks for the input, MFP!
Of course, you seem to work with a totally different "breed" of subjects than I do.
As mentioned earlier, I do mostly wildlife stuff, using telephoto lenses. (birds, wild animals and occasional scenery).
Seldom do I dwelve into portrait unless it is to get some "souvenirs" of family events.
So, back to the AA filter business: if Moiré pattern shows on one's shots, you are saying that it can be taken care off with PP, suggestively in CSxx (Photoshop). This would seem to be an easy way to fix the pattern. I have yet to check if this is available in my CS5.
What I do wonder is: would Moiré show in a bird's details, for instance? The feathers being a real trick of nature as far as complexity is concerned. I am talking about real close ups of the bird when one can observe fine details ... not so of course when taken far away.
JP
