10-11-2013, 03:45 PM   #16
Ex Finn.'s Avatar
QuoteOriginally posted by c-meier Quote
Thanks for the praise and support!
As for other "revolutionary" ideas: no, not at the moment. But the sensor-shift anti-aliasing was somewhat of a sudden inspiration, so who knows...
I am not a lawyer, so, legally, I have no idea where I stand. Maybe my post constitutes "prior art" or something similar, maybe not, depending probably on a lot of things, including when the relevant patent was filed. Obviously, the moral question is more relevant than the legal one... since only a camera and lens are in question.
I'll let Pentax decide if I earned it or not If I manage to contact them, that is.
EDIT: Sent the email to Ms. Amber Renard of public relations, only person whose e-mail I found. pentaxinfo@pentax.com doesn't seem to be working, either.
I wish you best luck in your quest for compensation. It would cool if they gave you an K3 and a lens.
10-11-2013, 03:51 PM   #17
QuoteOriginally posted by Ex Finn. Quote
Indeed. That would be very cool. It was at least worth a shot... And who knows, it might even be good publicity for Ricoh, since I'd make sure to be noisy about their generosity.
10-13-2013, 05:18 PM   #18
kh1234567890's Avatar
Unfortunately patents for this go way back, both for sensor and lens shifting. The problem has always been the actual implementation. Jiggling the sensor is NOT the same as a well designed AA filter which splits the light into four beams spaced apart by the appropriate sensel spacing distance.
10-14-2013, 04:22 AM   #19
QuoteOriginally posted by kh1234567890 Quote
I think it is also a mechanical issue. Probably the only reason it was not implemented on the K5IIs is that the mechanism could not be vibrated fast enough. It might still make sense though to implement it for slower shutter speeds. If it is good for 1/1000 on the K-3 then it could probably handle at least 1/250 on the K5IIs.
Something that makes me wonder is that they have stated that it is good up to 1/1000s but I have seen no mention of flash. I am thinking that with flash it will just not work. It will probably work fine if one uses HSS at shutter speeds between 1/200 and 1/1000 but that severely limits the effective GN. (At 1/180 or slower flash does not actually work in HSS mode and instead makes just one very short burst exactly as in non HSS mode)
(edit: in the second paragraph I am referring to the K3)
camera, dslr, filters, idea, k-5iis, photography
The Rumors Were True - K-5 II, K-5IIs, Q10, 560mm, 18-270mm, and more! Adam Pentax News and Rumors 163 12-10-2014 05:57 PM
K-01 Video Moire etc. tested yet? DrDespair Pentax K-01 2 03-18-2012 03:41 PM
Ricoh to make 16MP APS-C GXR zoom module bossa Pentax News and Rumors 13 01-03-2012 06:05 AM
10MP raw vs 16MP jpeg drakkar Pentax K-5 & K-5 II 8 10-26-2011 11:24 AM
ISO3200 JPEG from 16MP Sony Sensor (from Nikon D7000) kevinschoenmakers Pentax News and Rumors 96 10-31-2010 06:58 AM
All times are GMT -7. The time now is 08:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
