09-12-2012, 01:51 PM   #1
davidreilly3207's Avatar
Aperture in Tav, Manual Lens, K20D
Recently acquired a SMC Pentax 300mm F4 with no A setting. From what I've read, in Tav mode pressing the green button should stop down the meter to the aperature set on the ring and set the shutter speed for shooting at that aperture. After extensive testing, I don't hear anything when pressing the button and camera seems to shoot wide open no matter where the aperture ring is set.
Green button in TAv & M (K10D/K20D) is set to 'Tv Shift'.
Preview Method is set to 'Optical Preview'.
Using aperture ring is set to 'Permitted'.
The green button works correctly in 'M' mode and the camera shoots at the correct aperture.
Does this mean that the camera always shoots wide open in Tav mode or am I doing something wrong?
09-12-2012, 02:59 PM   #2
All that is true, except put in M mode -- not Tav -- and it will work. There is only M mode for that lens, essentially.
aperture, button, camera, dslr, mode, photography, tav
The aperture...when manual lens is not in use Spodeworld Troubleshooting and Beginner Help 8 08-29-2012 06:46 AM
Aperture problem with cheap old manual lens LarsW Troubleshooting and Beginner Help 12 05-23-2012 01:47 PM
manual aperture lens + popup flash. 006 Pentax K-5 2 03-11-2011 06:23 AM
Flash usage, and TaV or manual mode. JGB Troubleshooting and Beginner Help 5 11-09-2010 09:26 AM
Using Tav with fully manual lens Squier Troubleshooting and Beginner Help 2 07-09-2009 05:05 PM
All times are GMT -7. The time now is 11:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
