09-14-2012, 09:45 PM   #1
Upgrading From K-x
So I plan on upgrading from my k-x soon and I'm unsure of what camera to get next.
I'm currently looking between the K-5 and the K-30. I need help deciding which one to get. So please help me! Thanks!
09-14-2012, 10:41 PM   #2
Banned
Wait. Better things will be announced soon. And if not, then you'll be glad you kept your money.
09-14-2012, 10:46 PM   #3
QuoteOriginally posted by Laurentiu Cristofor Quote
Ahaha alright thanks for the advice
09-15-2012, 12:15 AM   #4
TZH
TZH's Avatar
I'll vote for K30
09-15-2012, 03:14 AM   #5
aurele's Avatar
i'd get the K30.
Why ?
The K30 has almost the same guts as the K5, plus an improve AF system (according to the first comments of the earliy adopters), improve live view and video fonctions, WR, etc ...
Now, the only thing the K5 have "more" than the K30 is few switch like Raw / jpeg, AF-S /AF-C, etc ... overall ergo is a bit better than the K30. But the ergo of the K30 is almost the same as the K-x, so you won't be any lost with the K30.
So, if, like me, you are always in the same file format and you don't change it often, if you always use the center point AF, and the center weight exposure, then the K30 may really be a better choice.
And it's getting cheaper
Just remember to pick a WR kit instead of the usual DA-AL (so, non WR) if you take the K30.
09-15-2012, 03:14 AM   #6
i_trax's Avatar
I would go with K-30 ( just received AA adapter , can share now batteries with K-x ) there is a lot about this matter on all forums + flickr
Flickr: Discussing K-5 vs. K-30, the question everyone is probably trying to avoid! in Pentax K-30
09-15-2012, 04:39 AM   #7
Anvh's Avatar
K30 would be a neatural step unless you will shoot RAW all the time.
09-15-2012, 04:50 AM   #8
Now than that's INTERESTING!!!!
I had often wondered about how different these two (k30 and k5) are in terms of image quality and ease of use and have always read high praises of K5, which I am sure it lives up to, but hardly heard anyone like k30 over k5. I don't own either hence don't know enough, but its interesting how k30 seems to measure up to its famous sibling.
09-15-2012, 06:29 AM   #9
Anvh's Avatar
K5 has more buttons so more manual input that is more suited for Manual mode shooting or more advance shooting for example.
The K30 delivers enough control to make the amateur shooters more then satisfied.
When it comes to image quality the K5 would have a slight edge when shooting in RAW, that's why i said when you shoot in RAW the K5 might be a better choice but that also depends on your other needs.
09-15-2012, 03:14 PM   #10
aurele's Avatar
I forgot the main advantage of the K-5 : the almost silent shutter.
And for me, well, that's the only big disapointement of the K30, the shutter is like the K-r : noisy !
09-15-2012, 07:59 PM   #11
On the pro side, ergonomically the K-30 is pretty good for K-x users - the K-30 button and knob placement is very similar to the K-x, for example, whereas the K-5 is very different. Green button placement, and play button placement too, IMHO, is better on the K-x/K-30 than the K-5.
You can also pretty much do everything with the K-x/K-30 in one hand (shoot, menu adjustments, review/play), with the K-5 you need two hands.
But the K-5 has a very quiet shutter, takes a grip, slightly higher fps, 14bit RAW, has an X-sync socket, microphone plug etc which are all useful things too.
09-15-2012, 11:02 PM   #12
Ahah I really like the idea of the quiet shutter and 14bit raw. But I like the improved auto focus and button placement of the K-30... Such a dilemma >.<
09-15-2012, 11:14 PM   #13
QuoteOriginally posted by lost.echo Quote
Isn't the autofocus capability of both cameras the same? Have read the K-5 excels in AF-C, especially compared to the K-7, and I would think the K-30 would be thereabouts too. Would be great to know from someone who has tested both for its AF-C focusing.
09-15-2012, 11:52 PM   #14
Frankly, I don't think you can make a bad decision here. Both appear to be excellent cameras.
I just made the decision for a K-5 to upgrade the K-x. The quiet shutter was a big factor, but also the accessory availability and magnesium construction for the K-5 over the K-30. I like to fiddle with my stuff and I'm also a bit careless, so ruggedness is a big factor.
09-16-2012, 12:11 AM   #15
Anvh's Avatar
QuoteOriginally posted by voyager13 Quote
nope one in the K30 is better and the one in k5 mkII should be even more better.
camera, dslr, k-x, photography
Upgrading from Kx ChopperCharles Pentax DSLR Discussion 3 09-10-2012 06:05 PM
Not sure how I should go about upgrading? Praestigium Pentax DSLR Discussion 15 01-04-2012 01:23 AM
Those getting a K-5 : What will you be upgrading from? adamfogerty Pentax DSLR Discussion 44 02-01-2011 02:42 PM
Help with Upgrading to either K-r or K-5 cjas Pentax K-r 16 01-13-2011 07:50 AM
Upgrading from the k10d to either k-x/k-r nirvanaguy19 Pentax K-r 10 11-04-2010 11:14 PM
All times are GMT -7. The time now is 03:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
