Originally posted by OrchidJulie If there was any sort of announcement, obviously I missed it. Dang. Well, I'll continue to be hopeful but investigate the alternatives. This is probably not the thread for the discussion, but how tricky is it to remove the spring from the non-Pentax adapters?
There wasn't really an announcement. When it disappeared from the web store the first time someone from the forum called Pentax and asked. The sales rep told them that it was discontinued.
The genuine adapters unfortunately get run up to $50 or more on evilBay. I got mine in January of 2010 for around $20. In that case the seller had listed it as an ASHAI adapter instead of ASAHI.
Check shopgoodwill.com as well. If you spend enough time looking through the camera listings you might find one with an adapter. I have seen several in the last couple of years.
