09-19-2012, 05:55 PM   #1
Capture Info in camera
few days ago I was out trying out my new used 50-200mm Sigma 1:4-5.6 on new used K-7
Now I process in LTRM 4.1 and in Library mode where you can read about the camera setting and other stuff
Now let me say This I do not own a Sigma 70-200mm 1:2.8 so why is the lens showing up in the capture file and not the Sigma 50-200mm lens
any thoughts: thanks
09-19-2012, 06:19 PM   #2
baro-nite's Avatar
QuoteOriginally posted by sqjaw Quote
any thoughts
That your lens has delusions of grandeur?
Apparently lenses that transmit this information do so with an ID code, and manufacturers will sometimes reuse codes from older lenses. So that might have happened in this case.
09-21-2012, 07:43 PM   #3
IN the end result, I have found how to fix the problem But it will catch in the LTRM software and I am LTRM 4.2,
To change your lens type you need to go to the develop modal and on the bottom on the right side you will find
Lens correction section and below that word you will [ Profile] [?] [manual] you click on profile and then activate
enable lens profile correction's then enter lens maker and then enter the model of the lens
then click on setup in grey but click on the word there [Default] it will bring up a screen that should say to you [ if you want save profile]
that should work but does not for me. I am getting to feel their against me LOL
50-200mm, camera, capture, dslr, lens, photography, sigma
Capture Camera Clip System Dachiko Pentax Camera and Field Accessories 8 07-23-2012 10:52 PM
Capture camera clip system Jack Pentax Camera and Field Accessories 7 11-25-2011 05:19 AM
Question Camera Restoration Info ... Jean Poitiers Site Suggestions and Help 4 11-19-2011 07:35 AM
Camera settings and RAW capture gamgee Pentax DSLR Discussion 4 06-22-2008 02:45 AM
All times are GMT -7. The time now is 01:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
