Originally posted by JinDesu Advantages of the Nikon D7000:
Significantly more lenses available- 169 lenses vs 90 lenses - Around 90% more lenses available.
I was just going to point out that on a raw absolute count basis, yes Nikon (and Canon) have more lenses available. If you pull apart the numbers, and only count Nikon's (or Canon's) image stabilized lenses, then the counts become nearly equal. Neither Nikon or Canon really have any image stabilized lenses that are wide - some may argue that they are not needed. So, there is a little more than just the raw body count. In both the Canon and Nikon lens counts, each offers a range of aperture speeds also within several focal lengths.
That said, both Nikon and Canon offer longer telephoto lenses (over 300mm), along with the specialty lenses - tilt shift, more macro, a wider collection of appliances - tubes and teleconverters, etc.
So, the bottom line is where do your particular interests lie, and which lens system provides the coverage for your specific needs.
