10-01-2012, 10:34 PM   #166
Sankon's Avatar
^ if your manual lens is set to M not A ( which is an aperture switch, not focussing obviously ! ), the camera has no control over the aperture at all. Set it to whatever you want, it will stay there :-)
Paul
10-01-2012, 11:41 PM   #167
Pioneer's Avatar
I have had no problem using the aperture ring on my manual lenses. I put my dslr in manual metering mode, set the aperture I want and the shutter speed that should match and check the meter. Seems to work great!
I think it would be nice to be able to read the aperture in the viewfinder, and to have it show up in the EXIF data, so from that perspective I believe that it is a good idea to un-cripple, if that is what you call it, the K mount so that it works properly again. I would like to have the K-Mount on my dslr to work the way it does on my PZ-1p. That should not be that difficult to do.
10-02-2012, 01:00 AM   #168
QuoteOriginally posted by Pioneer Quote
Even on "non-crippled" bodies, the aperture was never displayed in the viewfinder, as they have no way of knowing it... The only available information available to non-crippled bodies is the amount of relative f-stops between the fully open position and the aperture selected.
So, un-crippling will enable a fully working Av mode and P-TTL, but EXIF would still be blank...
10-02-2012, 01:19 AM   #169
Canada_Rockies's Avatar
QuoteOriginally posted by dlacouture Quote
One niggly correction - certain models did display the aperture in the finder. The film KX I owned, for example, had a periscope affair that looked down on the aperture ring. This was, of course, absolutely useless with a converter or extension tubes.
10-02-2012, 02:16 AM   #170
Roob-N-Boots's Avatar
Count me in.
10-02-2012, 02:42 AM   #171
Davidw0815's Avatar
Yes, please. Open aperture metering with old lenses would be fantastic! I don't mind manual focusing, but stop down-metering is a pain. The split screen interferes with the stop-down metering, so accurate metering is a little tricky and time consuming...
10-02-2012, 02:49 AM   #172
Sankon's Avatar
Presumably the split-screen would interfere with open-aperture metering as well ... ?
10-02-2012, 03:08 AM   #173
Davidw0815's Avatar
QuoteOriginally posted by Sankon Quote
Well, the problem is, that the middle of the split screen darkens in low light situation which then interferes with the metering. With normal daylight it's not much of problem until f/4. But if you stop down further, the split screen darkens and the metering is off. If I meter for example at f/1.4 and calculate the correct exposure for f/8 everything is fine.
Furthermore, metering is no problem with my lenses with A-contacts. Even if the split screen still interferes with metering, you just need to adjust the exposure compensation. With stop-down metering exposure compensation needs to be adjusted for every aperture setting differently. So I'm pretty confident that a de-crippled K-mount will improve things.
10-02-2012, 04:13 AM   #174
Lowell Goudge's Avatar
QuoteOriginally posted by Canada_Rockies Quote
But that was a window in the bottom of the prism housing over the lens not a display feature. It was common on upper models. The K1000 did not have it but the KX did
10-02-2012, 04:14 AM   #175
QuoteOriginally posted by Davidw0815 Quote
It screws up spot metering but average metering is OK
10-02-2012, 04:16 AM   #176
You should check that it is not just the split screen but the camera too. Many cameras have issues with stop down metering and accuracy because the metering is nonlinear and needs to be corrected for true apertures
There was a lengthy debate about this when the K10 and K20 first came out. The K 7 is better, and the K5 better still but not perfect
10-02-2012, 05:28 AM   #177
Andi Lo's Avatar
Listing up your name in a forum is free, but I wonder if everyone is willing to pay extra for it; pentax community is usually very frugal. I suspect the difference in price will be more than replacing the M lenses with their A versions (except perhaps the 85mm) . If that's not the case, then great! It's not a huge issue for me though.
10-02-2012, 05:58 AM   #178
Davidw0815's Avatar
Sure, I've lost spot metering. I normally use center-weighted average metering with my K7 which works OK but needs some adjustments depending on the aperture setting. Thanks for all the detailed info.
QuoteOriginally posted by Andi Lo Quote
I doubt that. It shouldn't be too difficult to build a de-crippled K-mount. I mean my P30t got one and that thing cost like $ 100 - brand new. And if you compare the prices of M and A lenses... You should be able to get a M28, a M50 1.4 and a M135 for around $200. The A135 alone will cost you that...
10-02-2012, 06:23 AM   #179
Giveaway winner!
MysteryOnion's Avatar
De-cripple it!
10-02-2012, 06:47 AM   #180
This assumes pentax has not got something either planned or presently, in the space the decrippled mount would occupy as a starting point. As i have said, sure I support it, but maybe somewhere in the master plan they have, it is simply conflicting with something else (let's leave the sinister market control issues out of this for the moment)
BUT there is a down side to this, in case people have not noticed.
K and M lenses are already scarce, therefore putting a de-crippled mount will only force the price up, because supply is already limited.
Not that I would mind, with my 20 or so K mount lenses but the issue of backwards compatibility from a practical point, of someone entering the DSLR lens market today, is quite different than it was 9 years ago. Just from an availability point of view, what you could get in 2003 for K mount lenses was incredible compared to today, and i am not talking price, but selection.
aperture, camera, count, de-cripple, dslr, k-mount, lenses, love, mount, pentax, photography
For Sale - Sold: Ricoh 105mm f2.8 Rikenon P Macro Pentax K mount w/ original caps and case ducdao Sold Items 16 08-31-2012 05:19 PM
Ricoh Rikenon 135mm 1:2,8 (K-mount) vs. Jupiter 37AM 135/3.5 MC (M42 mount) vlazduhu Pentax SLR Lens Discussion 23 02-16-2012 12:57 PM
Petition pentax for all black k-01 illdefined Pentax K-01 59 02-10-2012 10:25 AM
Ricoh GXR Leica M-mount APS-C module, K-mount next? LFLee Pentax News and Rumors 60 10-18-2011 07:11 AM
For Sale - Sold: 5 Manual K-mount lenses (pentax, ricoh, kiron, sears, JCpenny) GatorPentax Sold Items 9 09-27-2008 03:53 PM
All times are GMT -7. The time now is 05:31 AM. | See also: NikonForums.com, part of our network of photo forums!
