09-28-2012, 03:07 PM   #1
Can FA Lenses Cover FF Dimension + SR Movement Distances?
Sorry if it's answered before, but I just wondered, when an FF sensor is moved in both axis (say +-4mm) for SR, could FA lenses image circle can cover FF sensor size plus +-4mm, any ideas?
09-28-2012, 03:14 PM   #2
TOUGEFC's Avatar
Being that the FA Limiteds were made too be as compact as possible(and made before SR came along), I'd say no they probably wouldnt cover FF Dimension + SR Movement Distances
09-28-2012, 03:17 PM   #3
Ooh boy, if that so, the conclusion would be for an FF camera a new lens line is needed or big&heavy 645 lenses must be used on FF right? Another saying FF dream is stuck with the in-body SR.
09-28-2012, 03:22 PM   #4
You could find out by putting 35mm lenses on a medium-format camera and taking some snaps!
In any case, from a business standpoint, it's desirable for the answer to be "no" so that a brand-new line of full-frame lenses would have to be marketed, and perhaps that's why this seed was planted. On the other hand, given that only the corners of the frame are critical, I'm sure that in general most of Pentax's full-frame lenses give you plenty to work with.
09-28-2012, 03:33 PM   #5
You could find out by putting 35mm lenses on a medium-format camera and taking some snaps!.
Who makes a K-mount to 645 adapter? I know you can put a 645 lens on a K-mount, but not the other way around. It would never focus.
But it is an excellent idea just to test image circle. Which medium format camera can you put K-mount lenses on?
09-28-2012, 03:45 PM   #6
I think an easier way to do it, if anyone's inclined to do this test (I'm not), would to take a K-mount extension tube and mount it in a small box, with the mount 45.5 mm from a translucent sheet of some kind -- like a sheet of thin paper or transparency film with accurate sensor-size outlines printed on it and centered.
Then you can just hold this thing up in reasonably bright light, move the focus/zoom mechanisms around, and see what happens to the image circle in comparison to the printed outlines.
Obviously this wouldn't help too much to figure out things like vignetting or edge-to-edge sharpness (except to the extent you could eyeball it), but it would indicate the overall size of the image circle projected by a lens.
I tend to think all of the mainstream current and past FF lenses would pass this test.
09-28-2012, 04:00 PM   #7
jeffshaddix's Avatar
See falk's comments here:
https://www.pentaxforums.com/forums/pentax-news-rumors/107970-k-rumors-report...ml#post1117001
09-28-2012, 05:51 PM   #8
maxfield_photo's Avatar
4mm sounds like an awful lot, from whence does this figure come?
09-28-2012, 07:11 PM   #9
QuoteOriginally posted by maxfield_photo Quote
How much movement does the Sony A900 require? Looks like at least 3mm.
09-28-2012, 08:25 PM   #10
Otis Memorial Pentaxian
I don't think it would be something to worry about. Image circle is not an absolute cutoff and both the FA 35 and the FA 77 have negligible vignette on 35mm film. (Those are the two FA lenses I own and I shoot them both on film as well as digital.) I would expect NO vignette attributable to SR for vertical movement and little, if any, in the horizontal dimension.
09-29-2012, 12:27 AM   #11
Fogel70's Avatar
I wouls say that SR is possible on FF with FA lenses. I don't think more than +- 0.5mm is needed for 4 stops of SR on FF.
09-29-2012, 01:07 AM   #12
I've said (say +-4mm) which means it's just my imagination, if someone knows the true distance please let us know.
My simple logic says if there is even a slight vignetting exists without SR, with SR movement, that existing vignetting will increase at the opposite side of the SR movement in that particular exposure period.
09-29-2012, 04:09 AM   #13
Lowell Goudge's Avatar
QuoteOriginally posted by Quicksand Quote
Your idea is pretty good, but I would add one or two things. First, do this at infinity focus, because as you increase magnification it is likely the projected image circle also increases, and second, photograph the illumated circle. To do this it should be a tissue paper with concentric reference circles drawn on it. Use a photo editor to measure greyscale value. That will give you an accurate assessment
10-01-2012, 09:56 PM   #14
Class A's Avatar
As Falk (falconeye) posted multiple times, SR simply does not represent an issue for an FF sensor.
Even for a four stop advantage in SR, you need less than 1mm overhead in the image circle.
10-02-2012, 08:32 AM   #15
Blue's Avatar
On top of that, I would be willing to turn off SR with my FA 77 LTD, A 50/1.2, K 28/2, Tammy 180/2.5 and F 28/2.8.
camera, dslr, fa, fa lenses, ff, lenses, lenses cover ff, photography, sensor, sr
T-Dimension and codes on E-Bay molko Pentax K-5 & K-5 II 19 08-27-2011 10:27 PM
Macro View into Another Dimension . . . . Sailor Post Your Photos! 4 04-05-2011 05:08 PM
hyperfocal distances Tommot1965 Pentax SLR Lens Discussion 20 01-04-2011 01:49 AM
Goodbye 3rd dimension jeffkrol General Talk 10 10-25-2010 07:45 PM
Are there any F2.8 Macro lenses that are STILL F2.8 at macro distances? Unsinkable II Pentax SLR Lens Discussion 58 10-03-2010 05:25 PM
All times are GMT -7. The time now is 02:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
