02-04-2008, 10:34 PM   #1
Remotes for K10D E, D, F, !?!
What remote is best used with the K10D? E has a zoom button for applicable P&S models, F and D apparently just have a button. If you hold down on the button does the shutter remain open? I understand from other posts on Pentaxforums that when in remote trigger mode it times out in 5 min. I prefer the pentax remote, but is anyone having success with the third party remotes ? I primarily use the release for fireworks, some animal pics and group pictures that i'm trying to elicit more than a stare at the camera from the group.
Thanks!
02-04-2008, 10:37 PM   #2
I got an F remote this saturday for my k10d, and it holds the shutter open for as long you press it.
I wish it had an autofocus option, but it does not. You have to prefocus before you can use it.
02-04-2008, 10:52 PM   #3
ranamar,
There is an option in the custom menu to enable auto focus with the remote control. It is defaulted to off...
02-05-2008, 01:53 AM   #4
Would that be why my two button remote just operates the shutter without focussing first?
First (focus) buton closes sleeve and ring on the 2.5mm plug
Second (shutter) button closes sleeve and tip on the 2.5mm plug
Both just seem to fire the shutter
02-05-2008, 04:20 AM   #5
Does anyone know if the D remote fits inside the battery grip for the K10D? I think the F does, but hasn't Pentax progressed from F stuff to D stuff?
Brian
02-05-2008, 11:54 AM   #6
Groucho's Avatar
QuoteOriginally posted by pw-pix Quote
If you're using a wired connection (as I assume you are since you mention a 2.5mm plug), you should definitely be getting autofocus to happen when you press one of the buttons - it should do exactly the same as half-pressing your shutter, including metering, etc.
I built my own using parts from Radio Shack, an old telephone cord, and a Tic-Tac container, and it works great for about $3 in parts.
The design is so simple that I doubt it makes any difference who builds the remote, and Canons use the same design, so you could use a Canon remote.
As for the setting in the custom menu, I believe that's only for wireless remotes. Which is fine as the OP was discussing a wireless remote I believe.
button, camera, dslr, k10d, photography, remotes
KX Remotes compared Warren s Pentax DSLR Discussion 21 04-09-2010 07:50 AM
K20 timer remotes insulinguy Pentax DSLR Discussion 0 09-03-2009 11:42 AM
Anyone using Flashpoint 4 strobe remotes???? CaymanImaging Flashes, Lighting, and Studio 1 08-16-2009 05:34 AM
Do these ebay remotes work with K10d? Hannican Pentax Camera and Field Accessories 3 08-14-2008 09:01 PM
K10D and IR remotes joefru Pentax DSLR Discussion 1 05-19-2008 09:07 AM
All times are GMT -7. The time now is 06:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
