Thanks to everyone for the input.
Regarding PP. In 99% of the cases I shoot RAW. PP doesn't daunt me but when I say unreliable metering I mean that very often I have to add over 1 - 2+ exp in lightroom which does bring a lot of noise.
"i use the k5 and the D7000 (better high iso performance than the D300!).
the only difference for me is the AF-speed. the Nikon AF is a bit better (AF tracking with fast objects). I don't use flashes, so i can't say anything about that."
Does the D7000 have a more advanced AF sensor over the D300, the same or inferior?
"Wasn't the D300 updated to the D300s, with the same sensor (roughly) as the D90 and K-x? That's the one you'd want to get if you go down that path. "
As far as I've read the the D300s ads "minor" improvements to the D300. It's not that I really care about those improvements, like video shooting. Sensor is identical to D300, D90, k-x, k-r and D5000 (think D5100 ass well).
"I had the D300 and now have a K5. "
This is what I was looking for. In terms of AF-speed AF-accuracy and metering, is there noticeable difference between the two of them?
"I hated the Kx's AF performance. The K30 is much more decisive and fast. If you can wait for the K5II, it should improve on the K30. The K5 is a funny one. It doesn't seem as responsive after playing with the K30 but it may have more to do with using different lenses on both the K30 and K5 that made the difference."
This is what I'm scared of. The k-5 is a great camera but it does lack behind in some areas that I consider important. The k30 is IMO the best in it's bracket, hands down. But the lack of a grip really doesn't give me confidence.
"I keep reading this sort of thread, but invariably get the feeling that they're often written and driven by photographers who really haven't taken the time to learn and understand photography"
I agree with you, I'll learn as long as I'll live. So will you.
"seem to believe in the 'grass is always greener..."
No it is NOT. I'd be missing a lot of Pentax stuff, like compact and light bodies, in body stabilization and great ergonomics.
But I think that on the AF and metering side, the Nikon grass might be a tad greener. This is why I'm writing here, to really understand if it is true or not.
"I'd also say, lastly, that if you are serious about getting into wedding photography, your first duty is to your customers. Buy new, buy two identical bodies, buy the best."
We are in different countries and very different economic situations. You might afford to buy two of the best identical bodies, I don't.
I've seen the sort of equipment and output the photographers have here, not everyone. Low end body, kit lens with built in flash. In one hand the video camera, in the other the photographic camera. This is what I will target first. People with small budgets that want to capture the moments of their life. Then if successful move on.
