02-06-2008, 12:27 AM   #16
QuoteOriginally posted by JMS Quote
Heck with that, the finger just mashes the shutter release.
As little laker said, we already have that. It’s called “focus trap”.
02-06-2008, 10:09 AM   #17
dwhopson's Avatar
Is "trap focus" available on the K100D super? I know I've seen people talk about it on the K10D... If so, how do I set it up on the K100D?
The next question is...is it accurate?
I've been trying to use the focus confirmation beep/green light with k-mount 28mm f2.8 and 50mm f/2.0 lenses and haven't gotten as "crispy" a shot as I'd like. If I continue to work at the focus I can get the focus detail I'm looking for, but it isn't necessarily confirmed with the beep/green light.
Could this be a side affect of somewhat low interior lighting?
02-06-2008, 10:22 AM   #18
If I am not mistaken, only the center focus point on the K10d will work with a manual lens.
02-06-2008, 02:08 PM   #19
Red
QuoteOriginally posted by flyer Quote
I was thinking the same thing. It alerts you but doesn't indicate what is in focus.
02-06-2008, 07:42 PM   #20
dwhopson's Avatar
Ok....I understand how the "trap focus" capture works now.
(Took me a minute to figure it out....I'm a little slow sometimes )
I see if I'm very slow in adjusting the focus, it comes pretty darn close to being spot-on.
Cool...I learned something!
02-06-2008, 10:04 PM   #21
Wow!! had an unexpected result and had to delete test and retype my message, it appears to work for both Auto and Center focus, also it's like the trap focus is like a "single focus" and not continuous, I had to keep pushing 1/2 way down on the shutter button a bunch. My expected result was that only the center would work, or even on auto it would only try and detect a center focus, but I was wrong!!
02-06-2008, 10:19 PM   #22
Canada_Rockies's Avatar
QuoteOriginally posted by nex1 Quote
Trap in focus works best for me by holding the shutter release all the way down. Moving the camera, or waiting for the subject, with the center focus point directed at what you want in focus will trip the shutter at the exact point of focus. I use this method constantly with my M 100/4 macro when I am using it hand held.
I first tested this when I got my SF-1 by setting it up at a hummingbird feeder. It took three in focus shots of the local fast movers while I ate supper, using a locked down release cord.
02-07-2008, 12:44 AM   #23
QuoteOriginally posted by Red Quote
A green dot says you are in focus, a beep says you are in focus, a red square tells you where the focus is, and the camera can even release the shutter for you when in focus. If that isn’t enough help with manual focus, then maybe manual lenses aren’t your cup of tea.
02-07-2008, 12:46 AM   #24
QuoteOriginally posted by marcdsgn Quote
I hear there's a new model coming out for those with poor eyesight and hearing: Once the lens is focussed, a little finger shoots out and pokes you in the eye.
this is a niftier feature
02-07-2008, 02:10 AM   #25
QuoteOriginally posted by Gimbal Quote
"can even release the shutter for you when in focus" can the K10D do this? if so how? that sounds neat. I've even read the field guide for it, I don't recall this feature.
02-07-2008, 02:39 AM   #26
Yes, that’s the ”focus trap” function, it only works with manual focus lenses though. Set the focus switch on AF.S and press (and hold down) the shutter button, then turn the focus ring or move the camera or the object, whenever focus is found the shutter is released.
Read Canada_Rockies post again on how he “traps” birds when they fly into focus.
02-07-2008, 02:59 AM   #27
Holy crap that is amazing....
...... I just reread Canada_Rockies's post, NOW I completely understand it!
I love this message board.......
the possibilities of the usefulness of this application are endless.... excuse me while I go take over the world.....
02-07-2008, 01:36 PM   #28
bimjo's Avatar
It'll be a much smoother conquest with a cable release.
02-07-2008, 04:34 PM   #29
QuoteOriginally posted by little laker Quote
That's where focus lock works. Switch the camera to AF and if the rest of the settings are right it'll only take a picture at that point.
You can also set the OK button so it temporarily disables AF; so if you want to your focal point to be somewhere other than at the little red dot it's only one press of a button away.
And this is on the humble K100D Super!
02-07-2008, 05:06 PM   #30
Syb
Syb's Avatar
QuoteOriginally posted by Canada_Rockies Quote
you mean... your SF-1 Supper?
Syb
auto, beep, camera, dslr, focus, focus beep, photography
K7: Even with Manual Focus it gives off the AF beep? Daemos Pentax DSLR Discussion 12 10-14-2010 11:47 PM
Focus Confirmation bensonga Pentax Medium Format 1 03-25-2010 09:10 AM
Focus Confirmation?? slinco Troubleshooting and Beginner Help 14 01-15-2010 04:53 PM
Can Auto Focus be set to BEEP voicelit Pentax DSLR Discussion 9 10-08-2008 11:06 AM
Question on Ist-D focus confirmation on 3rd party manual K lens brainanta Pentax DSLR Discussion 13 03-21-2007 09:22 PM
All times are GMT -7. The time now is 03:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
