I used my k-5 to shoot some scenes at the waterfall without the grip. Dipped/splashed, everything imaginable except dropping it.
Came back home, dry it with tower till it is dry and put the body in dry box.
2 weeks later try to put on the battery grip. The connector at the body has some oxidations.
I forgot to take off the rubber cover at the bottom of the camera before putting it back into the dry box.
Some moisture must have trapped there.
Rear wheel of the grip couldn't change the aperture value. Take the grip off and scrapped some black-ish stuffs on the connectors,
clean it with WD40, rub it till it is almost clean.
That took about 2 hours of putting it back to the body and took it off again til the rear wheel of the grip can change the aperture value.
