10-13-2012, 09:11 PM   #1
Buschmaster's Avatar
Oh God, what is this?!
So I've uploaded a full image, as well as a 100% crop, in the crop you should see two dots that shouldn't be there.
The one on the left is blue and more bright, then just above the C there is a more purpleish one...
What has happened to my beautiful beautiful camera? Just noticing these tonight, not noticing them on the pictures I took earlier today...
PENTAX K20D  Photo
PENTAX K20D  Photo
10-13-2012, 09:25 PM   #2
paulh's Avatar
Hot pixels - very common, especially on older cameras. My *istD has about a half-dozen or so. I usually clone them out in pp. I think the K20 has a pixel-mapping function that allows you to deal with them. Someone more knowledgeable than me on the K20 can help you - or take a look in your manual.
10-13-2012, 09:25 PM   #3
Just a hot pixel, don't look that close and you'll never see them.
10-13-2012, 09:28 PM   #4
jeffshaddix's Avatar
Hot pixels can come and go, just use your pixel mapping function. I had them occasionally on my K-7, which used the same sensor as your K20D.
10-13-2012, 09:29 PM   #5
Is there any way to make them come and go (Particularly, GO) or not?
Thanks all. The reason I posted the second pic was to show how minor the problem is.
10-13-2012, 09:46 PM   #6
Sagitta's Avatar
I had a hot pixel pop up on my old Powershot. The ability to nuke the things on a Pentax almost makes the brand worthwhile alone. I think I have about a year and a half of hot pixel action going on my old Powershot images because the camera had no internal way of zapping them.
10-13-2012, 10:02 PM   #7
QuoteOriginally posted by Buschmaster Quote
ISO can affect it, you might notice more hot pixels at high ISO.
10-13-2012, 10:12 PM   #8
Lightroom and some other RAW converters will also automatically get rid of them on import. I've got them on my K10D (which has no pixel mapping), but never see them because LR gets rid of them.
10-13-2012, 10:27 PM   #9
Awesome! Thanks all!
10-14-2012, 09:57 AM   #10
As I remember it, if you put the camera in manual mode and take a 30 second or longer exposure with the lens cap on, it remaps the pixels. I did that on a K100D once & it did the trick.
10-14-2012, 12:56 PM   #11
I'll try that now!
10-14-2012, 04:07 PM   #12
QuoteOriginally posted by GibbyTheMole Quote
As a permanent fix even for shorter exposures? Are you sure you weren't just kicking the the noise reduction for long exposures that may have eliminated them from what was otherwise a dark frame for that single shot with the lens cap on? Neat trick if it works, but I'm skeptical...
10-14-2012, 05:34 PM   #13
Yep... And here's where I read about it. Worked for me, but I can't guarantee it'll work for others.
10-14-2012, 05:43 PM   #14
Cool, I'll give it a try on my K10D -- definitely has a few hot pixels now.
It isn't actually remapping them (which is a computer function of identifying the bad ones and averaging around them), just attempting to unstick them.
10-14-2012, 06:30 PM   #15
alohadave's Avatar
There is a difference between a hot pixel and a stuck pixel.
Hot pixels tend to show up when the sensor heats up (like during long exposures). Generally when you take shorter exposures, or wait for the camera to rest, the hot pixels will go away. They'll also be in different places on different times (different days or after some time has passed).
If the exposure is long enough to kick in the LENR, it's not unsticking anything, it's just using dark frame subtraction to edit the spots out. The next time your camera turns on, the pixel is likely to have cleared on it's own.
A stuck pixel is one that is always on, and you may or may not see it all the time, depending on the exposure and what color is surrounding the pixel in various shots, and what level of detail is near that pixel.
camera, crop, dslr, photography
Streets With God's help .. Velja Post Your Photos! 3 04-30-2012 05:44 AM
Genesis 1 if there is no God... JohnBee General Talk 64 01-20-2012 08:24 PM
People Connecting with god yusuf Post Your Photos! 6 08-04-2011 06:05 AM
Oh god! Now what? slr_neophyte Troubleshooting and Beginner Help 9 06-01-2011 06:11 AM
a discussion on god... god i was bored.. Gooshin General Talk 9 02-11-2010 01:01 PM
All times are GMT -7. The time now is 01:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
