Originally posted by i.glisin Thus, formatting cards and deleting all pictures is NOT the same thing. Here is why: Deletion actually works by marking data blocks (sectors on hard drive) as available for re-use, so if nothing gets saved to blocks marked as deleted (in fact "available") turning back that indicator to "in-use" would apparently restore data (in fact, already stored data just becomes visible again). In contrast, formatting recreates the structure of the memory media, creating everything from scratch including empty data blocks. Along the way formatting checks media for defects and performs other housekeeping tasks. Once done, all is gone.
I must say that you are completely wrong.
SD cards use FAT16 file system. In FAT 16 neither delete nor format does not erase actual data from disk. Both delete and format just modify FAT (File Allocation Table). In case of format, new "clean" FAT is written. In case of delete, entry, pointing to the file is deleted.
In both cases data is left on disk/memory card intact and can be recovered as long as new data isn't overwritten over it.
I won't go into details of FAT16, if you want you can search Google and you'll find more than enough details on it.
In case of Amanda I suspect that she is doing something wrong. When you do it right, you'll recofer data from formatted card.
