02-06-2008, 06:45 PM   #1
OniFactor's Avatar
question about k1xxd onboard flash..
when you put the flash in manual, does it still emit pre-flashes? if so, are they too fast for the flash to work as an optical trigger for a non-smart sensor?
02-06-2008, 07:37 PM   #2
mattdm's Avatar
QuoteOriginally posted by OniFactor Quote
There is no actual manual mode for the built in flash. The setting described as "manual flash" just means "flash forced on", as opposed to "automatically decide whether a flash is needed". Either way, it does the pre-flash, and that will trigger your non-smart sensor too soon.
02-07-2008, 08:47 AM   #3
krs
Can you expand on the comment "... will trigger your non-smart sensor too soon."?
02-07-2008, 10:13 AM   #4
I worked on that problem the other day with my K100D and a Sigma EF - 500 DG Super
If your flash is anything like mine (I bought it for my Sigma SD14 camera) you can set it up as a slave, and get respectable results.
However you do have to program it manually.
if you want to you can get a general idea of what settings I used on this thread.
If you have any problems with it I might be able to help you out, but I'll be gone for several days. So please don't expect an answer right away.
02-07-2008, 08:04 PM   #5
OniFactor's Avatar
QuoteOriginally posted by little laker Quote
so.. wait. the sigma can synch with the two pulses?? tell me more, when you get back!
02-09-2008, 01:07 AM   #6
OniFactor's Avatar
i just thought of something.
if i use a cheap flash with a manual setting and no TTL, it'll only have one pulse, right?
camera, dslr, flash, photography
Nature Just playing around with my onboard flash photolady95 Post Your Photos! 2 08-02-2010 05:01 PM
Camera set up using onboard flash AussieG Troubleshooting and Beginner Help 5 12-02-2009 03:47 PM
Making some use of onboard flash pentagor Flashes, Lighting, and Studio 10 02-27-2008 01:24 AM
Pentax K10D and Onboard Flash matix Pentax DSLR Discussion 12 03-05-2007 07:53 PM
Using onboard flash with K-Series lens Alvin Pentax DSLR Discussion 7 02-09-2007 05:51 AM
All times are GMT -7. The time now is 12:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
