10-19-2012, 10:13 PM   #1
How to send camera in for servicing?
I have a K-x, which I purchased in January 2012. I understand I have a year to send it back for a first service or something, and as it's getting to be around that time, I'd like to go ahead and do that. is there some information about this somewhere?
Charles.
10-21-2012, 09:43 AM   #2
Also, I'm worried if they'll void my warranty because of my split prism focusing screen...
Charles.
10-21-2012, 11:58 AM   #3
Ex Finn.'s Avatar
QuoteOriginally posted by ChopperCharles Quote
Charles.
Is there something wrong with it?.
Here is C.R.I.S. website. Call or e-mail them to find out what you need to do.Camera Repair by CRIS Camera Services: Digital Camera Repair: Canon, Fuji, Nikon, Pentax, Ricoh, Sigma
10-21-2012, 10:53 PM   #4
Well, it has a spot on the sensor I cant' get rid of with a rocket blower or the sensor shake, and it front focuses pretty badly on some of my lenses -- but not all. Problem is bigger with zooms. Some lenses like the 55-300, 50mm f1.7, and Promaster/Pentax 100mm f3.5 macro are fine. But then, some lenses like the F 35-70, 18-55, and Tokina 35-70 will OFTEN miss focus even in bright daylight. You'd think the problem with the f1.7 lens it would be worse, but the 1.7 almost always nails perfect focus.
Mostly I figure, I get a free service, why not have them adjust it and look it over?
Charles.
10-22-2012, 02:46 AM   #5
Ex Finn.'s Avatar
Yes, especially if you have focus problems.
10-22-2012, 06:14 AM   #6
stormtech's Avatar
Free service? This is true if you bought the 2 year extended warranty, but I don't think it applies with the standard 1 year warranty.
10-22-2012, 08:55 AM   #7
Ex Finn.'s Avatar
Should be under warranty for focus problem. They will CLA it as a normal procedure since they are working on it.
10-22-2012, 12:33 PM   #8
So my question is, should I put the original focus screen back in? Or just leave it as-is with the split prism?
Charles.
10-22-2012, 12:50 PM   #9
ChooseAName's Avatar
Charles.
Just to be safe in the eyes of Pentax or the service center, I would put the original back in.
10-22-2012, 01:11 PM   #10
Put the original focus screen back in with stock shim -- if they find your screen is scratched, they will replace it, so you don't want them replacing your third-party one. Just ask them to clean, check, and calibrate everything (AF, electronic level, etc.) Also they will reset it to factory defaults so if you have any special settings you may want to write them down. (Lens adjustments go out the window with AF calibration, so don't worry about that.)
camera, dslr, photography
Need for Servicing? mecrox Pentax K-5 4 01-23-2012 02:56 PM
Canadians sending cameras to Eric H for servicing - did you pay duty? gabriel_bc Pentax Film SLR Discussion 23 04-05-2011 07:28 AM
Pentax MX - Servicing UK spock999 Pentax Film SLR Discussion 2 01-31-2011 04:54 PM
OK, what is the best way to send my camera back? NaClH2O Photographic Technique 10 07-06-2008 08:41 AM
Servicing Your Toy Papou Photographic Technique 2 11-02-2007 06:09 PM
All times are GMT -7. The time now is 04:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
