02-07-2008, 06:37 AM   #1
K110 on-board flash went "phhhht" - help?
My daughter's one-year-old K110's onboard flash went phhtttt, just after it fired. Now it does not work at all. The camera still works fine in all modes with the flash down.
Has this happened to anyone else? is it a big problem? and how much did it cost to get fixed?
Any suggestions or advice appreciated.
02-07-2008, 07:34 AM   #2
QuoteOriginally posted by Panache Quote
I'm afraid the bulb of the flash is dead. You either have to replace it or use an external flash (imo a much better option).
02-07-2008, 07:41 AM   #3
wlachan's Avatar
The circuit is faulty and usually the problem show up at the earlier stage if the flash was used often. This is not an uncommon issue and Pentax is familiar with fixing it. If the camera was purchased in Canada, it should be covered by the 2 years Canadian warranty and free of charge.
02-07-2008, 07:45 AM   #4
Moderator Emeritus
Yes the bulb has burnt out. But if you bought the unit new, Canadian dealers offer Pentax bodies with a 2 year warranty. Otherwise add an outboard flash. If her needs are not all that great, if you can find an AF200FG flash should do a good job. I'm not sure if Pentax Canada is bringing in this model, but it's shown in the USA on the Pentax.com web site:
Pentax Imaging
02-07-2008, 04:40 PM   #5
Thanks for the quick replies. I'll tell my DD and hopefully she'll have no troubles with the fix!!
08-22-2008, 02:14 PM   #6
My DD has used the camera all summer with no problems, as long as the flash is down. If the flash is up, nothing works at all. Now she is wanting to get it fixed, but I'm doubtful the warranty will still apply. It was bought off the forum here. Will Pentax have the purchase info if the serial number is given to them?
On the other hand, IF she decides to upgrade, does anyone know the for-sale value of the camera as-is?
Any comments/suggestions are welcome and appreciated.
08-22-2008, 02:45 PM   #7
wlachan's Avatar
I doubt very much Pentax Canada would fix it under warranty if you don't have the invoice. If the camera works with the flash down, then the circuit probably has a short somewhere and replacing it is never cheap for any cameras.
camera, dslr, flash, photography
News PentaxForums.com in the run for vBulletin "Board of the Month" Adam Site Suggestions and Help 4 10-08-2010 11:59 AM
Sports "Highside Exit" took 1st Place in DPReview "Missed It by THAT much, Part 1" Challenge MRRiley Post Your Photos! 27 02-21-2010 08:26 PM
K20d-Frame Count on panals..works w/"M" & "P" mode only? arbib Pentax DSLR Discussion 1 08-28-2009 05:47 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
Anyone bring "E2" fluid or the "Digital Survival Kit" on a plane? m8o Photographic Technique 2 07-31-2007 06:20 PM
All times are GMT -7. The time now is 12:12 PM. | See also: NikonForums.com, part of our network of photo forums!
