I've been working away again this afternoon, Today's chore reduce a D800 image to 4928 (the size of a K-5 IIs image, (reduce the image sizes and see where the FF advantage ends.
The first image at 1:1 was 1128 pixels wide
Here's the comparison..
At the K-5s native resolution there is still a clear edge to the D800. Look at the cloth fabric. You can see the threads in the D800 image.
Here's the image reduced to 800 pixels wide.
The FF resolution advantage has almost completely disappeared.
Here's the image at half size. Now there's absolutely no advantage to one over the other.
And here's the size the image would be printed at 300 DPI. I'm not sure at this size you your eyes could detect the difference if there is one.
So I would estimate that if you are going to reduce your D800 image to 3500 pixels or less you could have had just as good an image from a K-5.
There is no computer screen that I know of that goes to 3500 pixels... printing to 300 dpi, thats' 12 inches, or big enough for an 8x12.
I think it's fair to say that printed at 300 dpi ( or 16 inches wide) you wouldn't see any difference without a magnifying glass.
So essentially if you want a cut off point for which there is no advantage to the best FF made, on your computer, there will be no difference at up to 3500 pixel wide images.
On a print there will be no difference up to 16 inches @ 300 dpi.
I haven't done the printing yet to find out when the difference would be come notable printed at 300 dpi, I have no idea how much detail you can see @ 300 dpi, but I'm guessing it's very little, After 12 inches though there should be a difference if you're close to the image.
If you saw my guesstimate yesterday, you know I'm guessing at normal viewing distance, I'm not sure you'd see a difference up to 60 inches. But if you wanted to do the Gursky thing and have incredible detail, as much as possible, you'll get closer to it with an FF than you will with a K-5, but you won't get anywhere near his 5x7 Linholf with a digital back, or whatever it is he uses.
I think where you'd see a real difference between the two images would be with an 8 foot image printed at close to 100 DPI. There you would clearly see the difference. If you're going that large, it's going to be well worth the D800 for the improvement in image quality, if you want to see detail as you move closer to the print from a normal viewing distance. Somewhere between there (96 inches @ 100 dpi) and 12 inches @ 300 DPI theres a point where the difference will be noticeable. But I don't have enough experience to hazard a guess as to where that might be. My printer on prints to 19 inches, so it's pretty much a moot point.
This is a comparison of resolution only, as I pointed out earlier in another thread this is the most expensive image ever sold is not very high res. 250 million for this bad boy.
Whether or not you like the sharper image better is a whole different question and open to preference. It's quite possible to decide the K-5 is better for your shooting despite the lower resolution because you like the low res look. It's also quite possible to possible to prefer a D700 with 12 MP because of the narrower depth of field.
The difference between the K-5 is enough that if you wanted the big size crystal clear high res image with the possibility of the narrowest DoF, you made a mistake buying a K-5. But it also means that if you'll never plan to need an screen image larger than 3500 pixels and you never plan a print over a conservative 36 inches.. probably more like 48 on canvas.. you saved yourself a pile of money going Pentax. The extra resolution of the D800 is worth it, obviously only if you use it. And you have to go big to use it.
