02-08-2008, 07:08 PM   #16
distudio's Avatar
QuoteOriginally posted by ricardobeat Quote
Pentax also claims the sensor is able to compensate for rotation, unlike other IS systems. Very useful for supressing "shutter press" shake.
The SR mechanism can rotate and can be controlled to rotate (used to set fixed sensor rotation) but I don't believe that the SR system actively counters for rotation, if you can find a Pentax publication where it specifically says this I'd love to see it.
02-08-2008, 07:18 PM   #17
Hi Rob
I believe Ricardobeat is entirely correct when he states that:
Which would appear to contradict your opinion that:
That is, unless I've misunderstood the intention of what you were actually saying ?
Best regards
Richard
02-08-2008, 07:32 PM   #18
distudio's Avatar
QuoteOriginally posted by Confused Quote
Hi Rob
Best regards
Richard
As I said find a statement where Pentax say the SR counters for rotation. All I meant was that the mechanism is capable of rotation and can be controlled to rotate the sensor by a fixed amount, not that it actively counters body rotation during SR operation.
02-08-2008, 08:20 PM   #19
falconeye's Avatar
QuoteOriginally posted by distudio Quote
distudio, thank You for the informative answer given earlier.
Why did I ask for the number of axes the gyros can measure? Because there can only be two differences between hand-held Eigen modes and tripod Eigen modes: frequency and type. As long as the frequency stays well below Eigen frequencies it should work. But tripod vibration may use different types of modes (e.g., rotational rather than translational etc.). And then it may fail even if frequency is low.
Note that tripod, in particular stable tripods, have high Eigen freqency!
distudio, thanks for the comment on drift. You are right, that alone may be a killer, i.e., if the system behaves non-linear for minuscule shake.
Some posters here quoted the number of axes the sensor can be moved by. It is x-trans, y-trans, and z-rot within the sensor plane. That's as many axes as possible given the constraint that the sensor better stays in the focus plane That wasn't my question, though. It was about the number of axes the gyro can measure and I doubt that it is more than two (rotational x and y of the camera body and no translations). But distudio and me do not seem to know facts about this. But if there is no third gyro for rotational z, the SR won't be able to compensate for body rotation along the lens axis.
02-09-2008, 07:59 AM   #20
falconeye's Avatar
Update:
I got additional info about the gyro sensors in K10D by private mail.
They seem indeed to be Murata's ENC-03R GYROSTAR sensors and there seem to be exactly two of them, measuring angular velocity (not acceleration!) around the following two axes, both perpendicular to the lens axe:
- vertical
- horizontal
Their center point (location of sensors) is in the lower and front part if the right hand grip, below the infrared sensor.
The gyro sensors output is specified for in between 0.3 Hz and 1 KHz only. But this does not mean much because we don't know the sensor's magnetic drive specification.
BTW, there is not enough information gathered to rotate the sensor except if there is a third gyro sensor at a completele different location within the camera body. Thre is no indication for this, though.
02-18-2008, 04:45 PM   #21
This says nothing about DSLRs, but may be a hint: Pentax selects InvenSense for image stabilization
Look for "rotational": http://www.pentaxslr.com/pdf/Pentax_SR_system_explanation1.pdf
I remember before buying my K100D of reading somewhere about how the SR system in it was the only one able to compensate for the shutter press movement... can't find it now though.
02-18-2008, 09:14 PM   #22
distudio's Avatar
It's still only a dual plane rotational sensor and it was destined for use in the P&S range, the K10D definitely uses the Murata product that I mentioned above.
02-21-2008, 09:09 AM   #23
I use my 600mm with SR and a tripod. Did many tests with and without. It works when I use slow shutter speed and hendhold. If I use 2 s delay or remote, SR is not needed.
02-21-2008, 09:36 AM   #24
Lowell Goudge's Avatar
Hi again
Here is a previous quote from Lowell:
While people have written in that if you are on a tripod there is no need because the camera is stable, I am not sure that they have ever looked through a 500mm-1000mm lens on a tripod. There is all sorts of vibration, much of it very high frequency. This is why lots of pros use a sand bag to weight down the tripod.
Richard I'm glad some people actually remember what I post.
Best regards
Richard
As another point to raise, Manfretto makes a "long lens support" which is an extendible tube with a small bnall head on one end (for the camera body tripod mount), and a clamp on the other to clamp to a tripod leg. THis works very effectively to take out vibration at the tripod head which on long lenses is on the lens mount.
02-22-2008, 11:11 AM   #25
Hi again Lowell
FWIW I hadn't heard of such a device before as I'm not personally into extreme telephoto photography myself, but for those others who might be interested, here's a link to the Manfrotto product that you mentioned
Best regards
Richard
02-22-2008, 12:36 PM   #26
Hi again Lowell
Best regards
Richard
Richard
thanks for the link
FWIW, the effectiveness is not limited to such extreme lenses. I use it with my Sigma 70-200 f2.8 and 2xTC. It takes a lot of vibration out
Also, I use it with a slightly different orientation in terms of camera and tripod. I insure that the camera splits (if possible) the two rear legs of the tripod, and have the support come off at an angle. usually going down to the left. this cancells out not only vertical but a large degree of lateral motion. If the support goes streight down, it does nothing against lateral motion,
02-22-2008, 03:41 PM   #27
Hi again Lowell
Bet you don't half get some funny looks from the occasional passer-by when using this contraption........lol !
Still, when all's said & done, your pictures come out OK, so the last laugh is probably on them.....
Best regards
Richard
06-04-2009, 06:45 PM   #28
Class A's Avatar
As others have said already the sensor could rotate potentially. However, in actual fact the K-7 is the first model to actually exploit this.
The Imaging Resource Review of the K-7 says:
For a while now, we've been under the impression that Pentax's Shake Reduction systems not only compensated for vertical and horizontal movement of the camera, but for rotation about the lens axis as well. As it turns out, this in fact wasn't the case, the misunderstanding apparently tracing back to a translation error on documentation for the original K-100D.
06-04-2009, 11:56 PM   #29
Only with the K-7 can the Pentax SR work in 3 axes. All previous versions of SR were 2 axes only. My own experience with star trail photos at night on a tripod is that SR is a bad idea, likely due to the intermal frequencies that the SR cannot handle properly that others have mentioned. So if my K20D is on a solid tripod, SR is off. Otherwise, it is always on unless I want an intentionally blurred photo.
camera, dslr, photography, reduction, telephoto
M42 lens' & shake reduction Big Bob Troubleshooting and Beginner Help 11 06-14-2009 06:49 AM
F series zoom lens & Shake Reduction calicojack Pentax SLR Lens Discussion 3 02-22-2008 08:25 AM
Best long (affordable) telephotos? Finn Pentax SLR Lens Discussion 16 10-12-2007 01:44 PM
K10D, Shake Reduction & Tripod switch79 Pentax DSLR Discussion 28 04-19-2007 06:18 PM
Shake reduction & camera life Brew1brew Pentax DSLR Discussion 9 09-27-2006 05:58 AM
All times are GMT -7. The time now is 03:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
