10-27-2012, 02:49 PM   #1
sbroadbentphoto's Avatar
Sensor shift and size of focus points.
does anyone know if there is a correlation between the amount of distance the pentax sensor can shift and the large size of the focus points?
I wonder if the focus points have to be larger because it needs leeway for when the sensor moves to focus on the same point.
Maybe this is why canon and nikon have smaller focus point areas.
I don't know if anyone has asked this question before but it would be interesting to see if sony has the same problem.
10-27-2012, 03:20 PM   #2
HSV
In Pentax DSLR, the AF sensor and image sensor are separate assemblies. The image sensor shift for SR, composition, and leveling adjustments only affect the image slightly in composition (meaning, up/down/left/right displacement). The AF system is related (so to speak, but not really) to the front/back orientation...and the image sensor cannot shift forwards and backwards.
10-27-2012, 04:52 PM   #3
i see it was kind of a silly question, i forgot to take into account that the sensor doesn't even see the scene until after focus when you are using a viewfinder, but the focusing section does
10-28-2012, 08:15 AM   #4
QuoteOriginally posted by sbroadbentphoto Quote
Be grateful if you can please provide comparative measurements, or references for this?
Thanks
10-29-2012, 04:07 PM   #5
Thanks
I cannot provide any evidence, but have used a canon 60D and it seemed to follow subjects better with continuous AF (it was my only experience with it)
The Nikon D300s was an amazing camera to focus with. it just seemed so snappy, decisive and accurate.
10-29-2012, 06:43 PM   #6
Is that due to smaller point sensors
or just overall more sophisticated AF systems?
11-03-2012, 06:02 PM   #7
better AF system i guess
11-04-2012, 09:41 AM   #8
so... (not wishing to seem like "witch hunting", or "beating a dead horse")
why did your think this, please?
Thanks
camera, dslr, focus, photography, sensor, sensor shift, shift, size
Sensor Size and Pixel Size interested_observer Photographic Technique 5 02-04-2012 07:59 AM
Sensor shift. Usuqa Pentax K-5 30 01-16-2012 04:23 PM
Should I see focus points? New Englander Troubleshooting and Beginner Help 5 09-29-2011 07:16 AM
In MF, how much you need off-center focus points?? kales Pentax DSLR Discussion 8 11-02-2010 11:02 AM
Quick Question.. Please Help? K20D Focus Sensor size? designinme_1976 Pentax DSLR Discussion 2 10-02-2009 09:31 PM
All times are GMT -7. The time now is 02:57 AM. | See also: NikonForums.com, part of our network of photo forums!
