11-06-2012, 12:16 PM   #16
JimJohnson's Avatar
QuoteOriginally posted by JinDesu Quote
Sharpness is generally overrated for portraiture
Amen. When I started serious photography in the 1970's there was a general search for old lenses the same as I see now in other topic areas of this forum. Only what was desired was the old soft lenses for portrait work. Those re-sold lens often went for a premium price. The typical 50mm lens of the day (the same lenses that folks are often clamoring for today) was often considered too sharp for portraiture and I read countless articles and photography book chapters that talked about ways to artificially soften images.
It seems photographers are never happy with what they have!
11-08-2012, 09:05 PM   #17
Marc Sabatella's Avatar
QuoteOriginally posted by melissa.1031 Quote
Hi Marc,
I saw your post before I sent my last reply. Can you expalin what the "crop factor" is?
Jim gave a technical explanation, and Google would surely supply with your hundreds upon hundreds more pages of information. But let me try to give a non-technical explanation that will hopefully be more immediately helpful.
A given lens can behave very differently from one camera to another, depending on the sensor size. A 40mm lens, for example, produces a slightly wide angle image on a traditional film camera, but a narrower view - like a telephoto lens - on an a traditional DSLR like yours. A 50mm lens produces a "normal" image - neither wide nor telephoto - on a film camera, but a definitely telephoto image on your camera.
"Crop factor" is a term used to describe how much the images changes between cameras. Specifically, the crop factor of 1.5 means a 50mm lens on your camera produces an image similar to what you'd get from a 75mm lens on a film camera.
So the question of what focal length lens you want depends on what camera you want to use it on. And as I said, 50mm is a decent portrait focal length on your camera, but not so good as a general purpose indoor lens because it is too long. Conversely, 50mm is a good general purpose indoor lens on film, but not so good as a portrait lens because it is too short.
50mm, camera, dslr, lens, pentax, photography, photos
Pentax DA 50mm F1.8 review & 50mm shootout Adam Pentax SLR Lens Discussion 11 07-14-2013 06:28 PM
Looking at 2 old cheap lenses (50mm M f1.7 and Industar61 - 50mm f2.8). Any opinions? Codazzle Pentax SLR Lens Discussion 24 09-11-2011 10:34 PM
Should I buy Vivitar 50mm f/1.7 or SMC 50mm f/2 hockmasm Pentax SLR Lens Discussion 36 03-23-2011 06:16 AM
Wanted - Acquired: M 50mm f2 or other 50mm misterwiv Sold Items 5 01-08-2011 03:34 PM
All times are GMT -7. The time now is 11:48 AM. | See also: NikonForums.com, part of our network of photo forums!
