Originally posted by Vormulac How do you access the focal length menu? I noticed when I turn the camera on with either of a couple of old second hand lenses mounted it goes straight to the menu, but once I've selected it I don't know how to change it - rather annoying as both those lenses are zooms!
K10D with the camera on, select menu. press up on the 4 way controller ONCE, to get immediately to the bottom of the recording menu. Shake reduction will be highlighted. Press the right arrow once on the 4 way controller to get the focal length menu like on start up.
Or, since you may have changed lenses any way, just turn the camera off and then on. this way, if you have sensor cleaning programmed, that function will take place immediately after you change the lenses, insuring that if any dust got inside, it won't stick
