11-10-2012, 08:54 PM   #1
K7 firmware continuous shooting
Hi
I have recently updated my firmware from Ver 1.0 to 1.12 and have stuck a snag. I use Sandisk 95mb/sec 32Gb card. On the old version I could get a 26 shot burst before slowing down to write all the info to the card. Using max resolution and quality setting. Saw the update info on 1.12 showing better support for SDXC cards. Update went flawlessly but now I can only get a 4 shot burst and it seems to take forever to write the data to the card.
Is it a setting I have not set that I need to know about or can you update back to the original version?
I shoot a lot of on the water stuff with yachts and the burst mode is great for get the right water movement or catch the whole sequence of the wipeout.
ie
https://picasaweb.google.com/109401118301148256327/WedNov9
https://picasaweb.google.com/109401118301148256327/WedDec7
11-10-2012, 09:11 PM   #2
It could be because you have shadow/highlight correction or lens correction enabled.
11-10-2012, 09:37 PM   #3
hcc
hcc's Avatar
I have a K-7 and I tested systematically the Hi Continuous shooting performances. I have also the latest firmaware and there is no issue.
However, as hinted by Adam, you MUST switch off (kill off) ALL in-camera ostprocessing incl. Lens distortion correction, High ISO correction, Shadow/highlight correction....
Also you need to select JPEG 14 Mp [**] or less to have long bursts (eg 45 s (*)). If you shoot RAW, the output rate will slow down once the buffer is full.
(*) Yes, I shot continous shooting sequences of more than 45 s at 5.2 fps!
I hope that the info will help.
11-10-2012, 10:40 PM   #4
You are both geniuses. Thank you so much. Sticking with 4 star qualilty and can get 25 @ 5.2fps before it starts to slow down but the fast card means it can still get 2 plus for a while longer.
burst, camera, card, dslr, firmware, info, k7 firmware, photography, shot, update, version, water
Continuous shooting golive Troubleshooting and Beginner Help 6 11-03-2012 12:19 PM
Continuous Shooting Zenithon Troubleshooting and Beginner Help 5 11-24-2011 09:07 AM
Which mode are you? Single shooting or continuous shooting? RonakG Photographic Technique 39 03-06-2011 02:08 PM
Quick test of continuous shooting with new K-5 firmware (1.01) dgaies Pentax K-5 32 11-22-2010 02:57 AM
K7 High Speed Continuous Shooting tpeace Pentax DSLR Discussion 18 03-15-2010 01:10 PM
All times are GMT -7. The time now is 10:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
