11-22-2012, 04:48 PM   #16
No offense but, not for me they don't.
No offense but I doubt you have a clue what Nikon is doing...if they were sitting there wondering how Pentax got the performance they did out of the same sensor they use and how they could exceed it, how would you know?
I dont have to work for Nikon to know they are working on their successors. And you are probably right...they are bashing their heads on the wall as well to get that same significant leap in 'image performance' from Pentax all Nikon APS-C shooters are waiting for...
11-22-2012, 05:04 PM   #17
Yeah, I love my 18-135. Does that make me a Pentaxian, a Philistine... or both?
11-22-2012, 08:10 PM   #18
calsan's Avatar
QuoteOriginally posted by Anvh Quote
uhhhh you do know that the K10D was released and reviewed 4 to 5 years earlier right?
Point being?
11-22-2012, 09:53 PM   #19
Well...we think the 18-135 is great from 18-70, esp when you stop down if you want the entire frame sharp. Photozone did not test that focal length, but in our images 70mm is sharp at f8. We use the longer lengths for the center, but so what? It's wr and with our problems finding a good 16-50 da* it is the best all rounder for all weather. Period. The k5IIs will I think test higher on DXO than what has been talked about, we think 84. Reason? The Nikon D800E does it's magic by neutering it's AA filter with another filter, so it has the same amount of glass in front of the sensor as the regular model. The IIs removes the filter entirely(guess?) so there is less glass in front of the sensor, which should help sharpness, etc. we should start a DXO number pool! Ymmv as usual,
David
11-23-2012, 06:18 AM   #20
The only thing they have to do now is to update the AF system and improve the SD write speed. ;-)
11-23-2012, 06:23 AM   #21
JinDesu's Avatar
QuoteOriginally posted by photoman1 Quote
That'll be the k-3. As far as I know, they've achieved what they promised for the k-5, and it's more accurate than ever.
11-23-2012, 06:25 AM   #22
frank's Avatar
SD card access speed is much faster on K01 and K30, so I guess Pentax already solved this problem. It's just they are too lazy to put this (improvement) inside the new K5II/K5IIs. Actually I think they reused every piece of materials from the 2-year old K5 except a new AF sensor/module. That's why I think they can sell the K5II at $800 and still able to make some profit.
11-23-2012, 07:45 AM   #23
@ikershaw
That makes you a philistine because the 18-35mm is nowhere near the sharpest lens, it is only a convenience. +1 it is also a kit lens
SMC Pentax-DA 18-135mm F3.5-5.6 ED AL [IF] DC WR Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
11-23-2012, 10:42 AM   #24
Anvh's Avatar
QuoteOriginally posted by calsan Quote
Point being?
The K10D was very good compared to similar cameras off their time and as such the scoring reflects that.
The scoring is not update to this time frame.
So you can not compare a scoring that is done 4 years ago with a camera that is just out.
Same as with comparing reviews off computer processors that are 4 years old with the current generation.
11-23-2012, 05:30 PM   #25
Why does the K-5 have a better rating than the D7000 if they both use the same sensor?
11-23-2012, 06:48 PM   #26
normhead's Avatar
It's also about the processing software that produces your DNG or PEG.
That makes you a philistine because the 18-135mm is nowhere near the sharpest lens, it is only a convenience. +1 it is also a kit lens
I beg to differ, @ 24mm and f5.6 it has amazing sharpness and excellent border sharpness. Apparenlty the Tamron 17-50 is better, but apart from that I don't think there's another K mount lens that can match it. If you're crying about the sharpness of this lens, I'd sure be interested in knowing what you're comparing it to. At f 5.6 and f8 it has excellent centre sharpness through it's entire range. Even @85mm to 135mm where it's border sharpness is so weak it degrades it's rating it still has excellent centre sharpness. The CA is what you'd expect from a zoom, but sharpness? I don't think so.
See full results here.
11-24-2012, 02:50 AM   #27
Pentax did a decent job on the image processing part.
Here are a the 3 Key cameras that has proven that sensors worth from the get go
DxOMark - Compare cameras side by side
3 brands with the same (sony) sensor, all small differences in the end result. Basicly any camera with that sensor will provide great image quality.
11-26-2012, 10:14 AM   #28
QuoteOriginally posted by frank Quote
It also makes me think they purposely delayed putting in the new imaging engine that succeeds the 3-year-old PRIME II for more tweaks seeing that Canikon also delayed the next-in-lines to their high-end APS-C lineup... which will make next year's CP+ very exciting!
Won't change my decision on getting a K-5 II though, lol!
11-27-2012, 01:27 PM   #29
this is good??
11-27-2012, 02:31 PM   #30
normhead's Avatar
this is good??
The guy can't interpret his own results. Listen I can't make you go through all the lenses for Pentax to show you how good this lens is at 24 mm, or show you how many lenses that don't have the qualities this lens has are rated higher on this site. I've done it. I couldn't figure out how to tabulate the data to show you how out of line with his own data those comments are. All I can do is say. Read the data.
In the ranges tested 18 samples the lens had excellent center sharpness in 13 and were in the top of very good in the rest. @ 24mm and F5.6 it has excellent edges sharpness as well. In fact you would guess it would be a very good landscape lens from 22-45mm. But you won't know that reading the review. You'd have to look at the numbers, yourself.
The thing is, if you know it's got weak edges in the long end... there are still a lot of picture you can use it for.
Like this it doesn't matter at all that it's not sharp on the edges.
Nor does it on photos like this
There are a lot of circumstances where this is a great lens. If this particular review is anything it's an example of what happens if you lock yourself away in a little room with a test chart and start writing about lenses based on what you see on 2D charts. There's obviously another side to the story, and I have no idea why it becomes my job to explain that. You could have just gone and analysed his own numbers, like I did, then looked at the pictures to see if they are in anyway relevant. His test numbers are good, for 2D test charts. His conclusions are not. As far as I can tell, it was a Monday morning and the guy must have had a hangover when he wrote this review.
DA_18-135 Photos by Norm_Head | Photobucket
camera, dslr, k-5ii, photography
DXO Mark lens scores????? robert Pentax SLR Lens Discussion 10 05-12-2012 05:33 AM
K-5 Low light/ High ISO dpreview vs dxo mark conflict vodanh1982 Pentax K-5 5 10-07-2011 02:52 AM
DxO Mark lens testing and SMC? causey Digital Processing, Software, and Printing 3 03-31-2011 05:00 PM
D7000 can't catch K-5 at DXO mark ogl Pentax News and Rumors 60 11-20-2010 08:25 AM
DXO Mark : an interresting performance comparison site for DSLR cameras ghelary Pentax News and Rumors 30 11-20-2008 11:56 PM
All times are GMT -7. The time now is 09:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
