02-13-2008, 12:59 PM   #46
attack11's Avatar
QuoteOriginally posted by Jodokast96 Quote
Here's a grand idea. Don't underexpose your shots. It's no secret that the K10D (and most other cameras) benefit from being pushed as far to the right as possible.
don't know the trick of under exposing a stop to get a faster shutter then pushing the stop in post processing? it's common practice; just doesn't work when you go above iso1000 in low light with a k10d.
got any tips for shooting hand held in low light? i'd love to know what you'd do.
02-13-2008, 01:11 PM   #47
Tom M's Avatar
Underexposing your shot and pushing it in PP is no trick. It's a fix for a poor photo in the first place.
The better you understand what your equipment is capable of and how to achieve the best results from it, the better your images will be. And once you do, you'll see that ISO 1600 images from the K10D can be amazingly clean.
And FYI, it's not called 'hiding the noise', it's called, exposing to the right.. Try google.. It's how you get properly exposed images with little noise. No tricks, just a technique that works. Your welcome.
02-13-2008, 01:12 PM   #48
Gooshin's Avatar
QuoteOriginally posted by attack11 Quote
with SR you can do 1/10 easy i always overexpose 1/2 or 2/3 stop because my shots turn out dark.
for noise control you are better overexposing at the initiat shot then pulling back in post processing than shooting dark in camera then overexposing during post processing.
there is no trick, figure out a way to create a tripod with your arms and dont shake..
here are some slow shutter shots,
all are either exposed at 0 or +0.3 +0.7 EV.
1/10 iso 1600
1/10 iso 1600
here is a freaking 1/8 shot at iso 1600
and another 1/8 shot at iso 1600
02-13-2008, 01:15 PM   #49
Tom M's Avatar
attack - Here's another RAW for you to play with - I shot this, 1/90th shutter .. http://www.dslreports.com/r0/download/1240837~542dd37fe3692d89bb45f874d740d97d/IMGP9204.zip
I won't say it's noiseless but, lol, it's very noise free..
02-13-2008, 01:30 PM   #50
attack11's Avatar
QuoteOriginally posted by Tom M Quote
i can't believe you actually wrote that. it is common practice and considered a trick when you need a faster shutter than a properly exposed image will give you. practically every photog i know irl does this and they range from pentax to canon to nikon people.
if i had pushed the stop to achieve the higher iso while maintaining the fastest possible shutter i would have massive noise. you seem to be ignoring the drastic difference of noise in a well lit scene versus a shadowed scene. the pic of my friend blinking is very good for noise while anything in the poorer light is drastically different.
still can't believe you think i didn't have a plan when i set my camera up and gave it to a friend to shoot with. sigh.
i know how far i can push my 50/k10d combo for shutter, but that's only good for still subjects. 1/6 is as low as my hands can go, 1/10 is very easy to get. both are useless for people in motion.
02-13-2008, 01:31 PM   #51
Gooshin's Avatar
then dont complain about noise!
both are useless for people in motion .
here is a little photography trick, scream out "FREEZE".... if your friends are like mine they are quite used to it and listen.
also bar setting motion blur is not as bad as some people think.
02-13-2008, 01:32 PM   #52
attack11's Avatar
QuoteOriginally posted by Gooshin Quote
you do realize underexposing 1 stop and then pushing that stop puts me up to the next iso right? just gives me a faster shutter.
02-13-2008, 01:34 PM   #53
Gooshin's Avatar
having the shutter open longer is not the same as giving a stronger signal boost.
02-13-2008, 01:35 PM   #54
attack11's Avatar
lol. sorry, i just work my hardware to it's limits instead of relying on others to stop what they're doing.
that was the first time i've used my k10d in that kind of light situation and i was massively let down with how it did. my ist dl could handle that light better.
02-13-2008, 01:35 PM   #55
attack11's Avatar
you should read up on it.
02-13-2008, 01:36 PM   #56
Gooshin's Avatar
shooting at ISO 800 at lets say 1/10, then pushing it to 1600 in lightroom, will give you worse results than shooting at ISO 1600 at the same 1/10 then pulling back 1/2 a stop or more in lightroom.
02-13-2008, 01:40 PM   #57
attack11's Avatar
if you say so. i'll just ignore all the stuff i've learned shooting hockey in low light arenas. you've opened my eyes Gooshin.
02-13-2008, 01:41 PM   #58
Gooshin's Avatar
hockey is completly different than bars, you dont have a freaking luminous white surface covering 50% of your screen.
ive never shot hockey, but if you look at my galleries you will see over 60% of them are bars/clubs/streets at night, so if you want to ignore my advice on flashless bar shooting, go ahead.
02-13-2008, 01:43 PM   #59
attack11's Avatar
it's not as different as you seem to think. the same under expose/push a stop applies if you want the fastest shutter with the least noise. you gotta remember, you start with less noise at the lower iso always; pushing that stop doesn't introduce more noise.
02-13-2008, 01:55 PM   #60
Gooshin's Avatar
all i know, from personal experience, is that unpleasant noise originating in high ISO pictures (1600, since i dont have options between that and 800) is largely determined by whether or not i properly or over expose a shot.
trying to "push" underexposed high ISO pictures will most definetly get you horrible results, if thats how you do things then i'm not at all surprised at your distaste for using high ISO.
5d, camera, dslr, k20d, photography
For Sale - Sold: K20D, Battery Grip, NEW K20D battery, cable remote (Worldwide) Albert Siegel Sold Items 6 09-23-2010 08:02 AM
In Canada: Summer Rebates for K20d or K20d plus lens Pentaxtic Pentax DSLR Discussion 1 07-17-2009 11:34 AM
Magic Lantern Guides: Pentax K20D and MasterWorks: Jumpstart Guide for the K20D. Reportage Troubleshooting and Beginner Help 10 02-12-2009 10:24 PM
All times are GMT -7. The time now is 08:18 AM. | See also: NikonForums.com, part of our network of photo forums!
