Originally posted by robert I think I'll wait until I see a review done by an an imparcial tester....Bob
Hmmm... Well you'll never find an impartial tester as everyone has their personal opinions thrown into the mix when reviewing a camera, which is unfortunate, but true.
You should make the assumption from what you personally see and not always base on what a tester thinks, because the tester is human and makes errors not too mention never really test the camera like you would use it.
To the OP the sensor has a lot of neat tricks. It can TTL off the sensor during live view, it has a resolution that surpasses the lenses allowing for better overall resolution, the pixel size is large even the density is higher and allows for cleaner ISO at an expanded range. I think if you really sit down and look at the images from the K20D sensor you'll see the big difference between it and the one in a K10D or K100D.
