11-28-2012, 06:54 PM   #1
Marketplace Reseller
innivus's Avatar
EV and ISO
I shoot a lot indoors and in poorly lit situations. Not to mention my dog has black fur, which is impossible to get in low light.
I've been trying lately to compensate for this lack of light by increasing the EV on my k-5. The issue I've had is that as I increase the exposure, the ISO value also kicks up, automatically (I usually shoot in tAV mode), and in the end the picture doesn't 'lighten', but rather is now grainier. What should I be doing?
11-28-2012, 06:59 PM   #2
Don't shoot in TAv mode but instead lock the aperture at close to wide-open in Av, fix the ISO at something with minimal noise (i.e. ISO 800-1600) and then use the EV shift to make your image brighter. The K-5's SR should allow you to get good results at as little as 1/20s hand-held.
Also, make sure you're shooting in raw.
11-28-2012, 08:46 PM   #3
Canada_Rockies's Avatar
Further to Adam's (as usual) top flight comment, try spot metering the dog's fur and adding two stops of exposure (EV + 2.0). This is a warped take on Ansel Adams' zone system, and should get you in the ball park for starters. Tweak until the fur looks the way it should.
11-28-2012, 10:03 PM   #4
QuoteOriginally posted by Canada_Rockies Quote
I'm confused. Wouldn't you go -2 EV on the exposure compensation? I think he wants his dog's fur to look black, not 18% grey or something like that.
11-28-2012, 10:16 PM   #5
innivus's Avatar
QuoteOriginally posted by IchabodCrane Quote
To be fair, I just wanted to point out its tough to take a picture of a dark subject in low light. Trust me, I have enough pics of my dog.
That said, thanks for the answers everyone. I'll be sure to try out the suggested methods.
11-28-2012, 10:39 PM   #6
SpecialK's Avatar
Yep, underexpose dark things to keep them dark. The actual meter mode does not really matter. Use a different shooting mode, and just take a test shot and adjust EV according to the result.
11-29-2012, 05:57 AM   #7
JimJohnson's Avatar
Another suggestion is the lighting. If you can position a bright light above and just slightly behind the dog it will add a glossy look to the fur and give it more dimension. Just make sure you meter to the subject and not the rim lighting.
11-29-2012, 09:21 AM   #8
. Yes. mumble. With my "solution" the dog would come out white or light grey. I get so confused ....
camera, dslr, ev, iso, light, photography
Photos: K-5 at ISO 6400 AND ISO 12,800 PeterKBurian Pentax K-5 2 01-07-2011 07:01 AM
Linking ISO steps with EV steps kiwibird Pentax DSLR Discussion 21 01-03-2011 08:51 AM
I am getting a lot of noise at ISO 800 and ISO 1600.... Abstract Pentax K-5 19 11-30-2010 10:48 AM
Anyone else do this? ISO 100 and compensate with flash/EV/aperture? ChooseAName Pentax DSLR Discussion 14 07-29-2010 09:59 AM
Why does ev compensation set off auto iso? jake123 Pentax DSLR Discussion 12 02-29-2008 07:29 AM
All times are GMT -7. The time now is 11:12 AM. | See also: NikonForums.com, part of our network of photo forums!
