02-13-2008, 07:36 AM   #1
Can't take b&w exposures on K10D
I cannot take b&w exposures with my K10D; I follow the instructions given in the manual, but after pressing the Fn button in playback mode, I am unable to get the screen with the filters. Don't understand what I must be doing wrong; will appreciate any help from anyone on this.....
Thanks,
FLASH
02-13-2008, 07:40 AM   #2
Playback mode, press the Fn button, then the 4 way controller to the left, it opens up a vertical list of filters, press the 4 way button down or up, to the filter you want, and voila. Unless there is something wrong with your camera or I'm not remembering correctly.
02-13-2008, 07:41 AM   #3
if you're shooting in raw, you'll need to first convert the raw to jpg... then you'll be able to get to the filters... you can only use the filters on JPG images. it might be advantageous for you to just use some software on your computer such as Picasa (free from google.com) or some other image editor to get the black and white... you can do much more in these applications that you can do on the camera. Hope that helps!
02-13-2008, 07:45 AM   #4
Agree with Mitch - you'll get much better results converting to B&W in post-processing. Many more options, and you can play with the curves to get the look you want. You can't actually shoot in B&W on the K10D anyway - it's just an in-camera conversion. Better to do it later.
Cheers
camera, dslr, exposures, k10d, photography
Bracketed Exposures - K10D vs K5 Mark Morb Pentax K-5 10 09-29-2010 07:14 PM
Number of exposures on my K10d? Larsenio Troubleshooting and Beginner Help 3 07-21-2010 05:15 PM
K10D shows two exposures for same shot pentkon52 Pentax DSLR Discussion 5 07-07-2009 10:25 PM
k10d long exposures dubbs5050 Pentax DSLR Discussion 3 11-06-2008 05:16 PM
Long exposures & battery power Ash Pentax DSLR Discussion 11 08-01-2008 04:27 AM
All times are GMT -7. The time now is 11:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
