Originally posted by Jonas B I don't have a K100D and so I'm not able to check for myself. I would try this:
Take a picture withthe SR turned ON.
Check in PPL that the info is there
Convert it to DNG using the Adobe converter and
Convert it to DNG using PPL (if doable)
Check both pictures in PPL and ACR 3.6 respectively for the SR info
That's pretty much what I did, except you can't convert to DNG using PPL. Or at least if you can, it's so non-intuitive I couldn't figure it out. I think I'll try converting to tiff in PPL, open it in PS, and see if SR shows up.
Quote: The EXIF values are standard. Among the EXIF values there also are Makernotes that are not standard. I don't know where the SR is placed but it may be in inside the Makernote part and then there will be problem for most third party software to show the info as long as the maker of the software don't aim for it specifically.
Hm, that may explain it. Or as Photo Tramp suggests, maybe they rushed to make it compatible with the new cameras and missed some bits. Either way, it makes me wonder if I'm missing something more important.
Thanks all for your suggestions. If I ever figure it out I'll let you know!
Julie
