12-08-2012, 01:22 PM   #1
matchy matchy
so hi,
I have the pentax kx in white, and I wanted a for fun flash in white and I found the nikon sb-n7 and the nissin Di466. Does anybody know if either if these are compatible with the camera, or if there are other white flashes that would be? Also, is there such thing as a white lens hood that I could get? I know I'm such a girl!
12-08-2012, 01:26 PM   #2
Neither would work well, if at all. If you are going to use a flash meant for another camera system you're going to need to use a flash that has manual modes and preferably an auto mode with its own sensor. Neither of those flashes have anything except TTL auto mode, which only works with the camera it is dedicated to. Best case, it will fire full power every time and you can compensate by stopping down the aperture a lot, worst case, it won't fire at all.
12-10-2012, 10:15 PM   #3
abmj's Avatar
If a flash is not specifically marked for use on Pentax, I'd avoid it.
As for a white lens hood, try some nice white acrylic spray paint. Just leave the interior flat black or you will likely have reflections and more glare.
12-11-2012, 04:24 AM   #4
Thank you for your input guys!
camera, dslr, matchy, photography
All times are GMT -7. The time now is 05:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
