02-14-2008, 06:22 AM   #1
Long exposure dead pixels..?
hi,
I've just picked my K100d back up form Jessops after being sent for a replacement ccd after noticing loads of dead/stuck pixels , bright blue/green mostly
Now it has come back its, its even worse , loads of hot pixels, and just as many stuck pixels as before
http://i173.photobucket.com/albums/w60/szbrozek/Pentax%20K100d/14thFeb08repaired_iso200_30s.jpg
This was at the lowest iso200@30s, but got the same image at 1/4000th at iso1600 both with the body cap on, no lens.
This is driving me mad..
any comments..
02-14-2008, 08:10 AM   #2
Lowell Goudge's Avatar
is noise reduction on or off?
I have heard this can eliminate the problem.
also, shouldn't the service department map these, and exclude them. Somewhere I had read that it was possible.
02-14-2008, 01:19 PM   #3
I would have thought so.. I was told by the Customer Service Dept at Pentax, that the CCD had been replaced, I suspect they didn't check it and change the excluded pixel mapping..
I did try searching for pixel mapping 'out' software to update camera firmware, but only found 1 piece of software for 1 particular camera..
Anyone know if the software to map out bad pixels on the K'series Dslrs is 'get' able.. I mean out the back door at Pentax
02-15-2008, 03:24 AM   #4
Very strange,
I come to do some googling regarding pixel mapping, hot and stuck pixels ect..
I switched it back to Jpg mode, and took some at 250th/iso200 cold, and the same after leaving it on for a few minutes to warm all the circuits, nothing clean as a whistle..
Came across Michael Salzlechner's DeadPixelTest software, tried it out on a black/lens cap on photo, and behold, all those little hot pixels and even the stuck ones were not visible..?:S perplexed am I.. The software detected a possible 28 or so hot pixels (none visable), no stuck/dead pixels..
What concerns me is that at sometime those hot/stuck pixels will creep back into photos..
Anyone experienced this hot/stuck pixel dissapearing act.?
sz
02-15-2008, 04:53 AM   #5
distudio's Avatar
QuoteOriginally posted by szbrozek Quote
Very strange,
The temperature of the circuit/sensor has some minor effect on noise however exposure time is a far greater factor. Assuming that you have NR turned off the hot pixels should reappear in the same positions/colours if you make another 30 second exposure, probably even with the camera at 0 deg C. Stuck pixels remain visible regardless of the exposure time but hot pixels become brighter with exposure time. As the ISO is raised hot/stuck pixels become more noticeable.
For longer exposures (>=1 sec)when saving as jpg in camera it's best to leave NR turned on. The NR is a subtractive type, after the exposure is made the camera automatically makes a second exposure (with the shutter closed) for the same period of time and uses this second file as a subtractive mask.
02-15-2008, 09:08 AM   #6
Ive just been comparing before and after repair pics, and the same hot/stuck pixels are there, in the same places.!! :angry: especially after being told the ccd was replaced.. I feel totally cheated, not sure I trust Pentax, maybe Canon or Nikon have better Customer Service..?
I've had a moan at them on the phone already, and told the usual, just send it back with a letter explaining the issues and the fact that this is a 2nd return for the same repair..
Maybe this time they will get the idea of a 'repair'..
02-15-2008, 01:38 PM   #7
pixelsaurus's Avatar
You can remove hot pixels in long exposures by turning NR on but be aware,the cam will make a dark frame exposure equivalent to the original exposure before subtracting it. Not so bad at 1 sec but at 30 secs or longer,it becomes a bit of an ordeal. An alternative is to shoot dark frames seperately and subtract them in software; just make sure NR is off if you do this. This guy nicely made a web page to explain the technique,he has also included info on making and utilising bias frames ash's "Diamonds from the Rough" Page
camera, dslr, loads, photography, pixels
K7 dead pixels grayboy Troubleshooting and Beginner Help 3 10-13-2010 03:31 PM
DEAD Pixels shang Pentax DSLR Discussion 5 09-09-2010 11:12 AM
Dead pixels? Luke_ Pentax DSLR Discussion 8 08-10-2009 08:17 PM
dead pixel on long exposure question pentaxbling Pentax DSLR Discussion 2 08-27-2007 02:03 PM
Dead pixels! andrei46 Digital Processing, Software, and Printing 3 08-24-2007 01:01 AM
All times are GMT -7. The time now is 04:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
