Originally posted by Sprags When I open a *DNG file in Photoshop CS2 it shows that the Depth is 8 Bits/Channel. I though if I have the camera set for the highest quality image its supposed to be 12 Bits/Channel.
Is there a setting on the camera I need to change?
Thanks...Blake
You cannot set the bit-depth of a RAW file in the camera.
When you open a DNG file in CS2, ACR converts the 12bit RAW file to a regular image file. There is a user-settable "Depth" parameter in ACR which decides whether the output image file is 8bit or 16bit.
ACR either maps the 12bit RAW file into 8bits or pads it into 16bits as required.
Dave
