12-15-2012, 07:23 PM   #1
K-x, K5, K30 noise
I was mulling through my old pop photo reviews (I know, I know.....) and it's interesting that the newer generation K-5(1st version) and K30 have inferior noise numbers than does the k-x at higher isos.
It's plausible to me that for a given generation of sensor that a 12MP with its bigger pixels could have better noise performance than a 16MP sensor BUT in this case, they are not of the same generation so you would expect improvement.
Here's what the reviews say:
iso 200 400 800 1.6k 3.2k 6.4k
k-x 1.5 2.3 2.6 2.9 3.2 4.1
k30 1.3 1.6 2.5 3.9 4.4 6.8
k5 1.5 1.9 2.2 2.7 3.4 5.1
I don't know what these numbers exactly refer to other than higher is worse, but assuming they are all taken with nr set similarly, why does the k-x look superior?
Heck, the k-x is almost as good at 6400 as the k30 is at 1600iso!
And why does the older k5 look better than the K30 with - I thought - the same sensor?
12-15-2012, 07:28 PM   #2
If you really want to crunch numbers, I think the most reliable source would be DxO.
The reason the K-5 does better than the K-30, despite having the same sensor, is that the K-5 has 14-bit RAW, and Pentax may have also made tweaks to the K-30's image processing algorithms.
12-15-2012, 09:36 PM   #3
kiwi_jono's Avatar
I don't have the K-30, but I have a K-x and K-5 and I have done some controlled test shooting on outdoor and indoor scenes.
From pixel peeping (100% view) at high ISO (1600 - 12800) the K-5 is very close to the K-x (k-5 lower noise in dark blue areas but reds slightly better on K-x). It is not easy to compare subjectively because there are so many factors to take in to account (for example when noise reduction kicks in and camera sharpening etc). HOWEVER there is more detail in the K-5 images to work with, giving the K-5 an advantage.
From the sample images I have seen on DPReview I thought the high ISO images looked pretty similar between K-5 and K-30 but at default settings the K-30 appeared to be doing a bit more noise reduction (but I could be mistaken) .
03-28-2013, 04:58 PM   #4
Tord's Avatar
My personal experience is that the K-30 does a slightly better job at moderately high ISO (even if it doesn't go as far up as the K-5), but what really differs is the, in my mind, far better AF of the K-30. The K-30 has a more capable processor (inherited from the ugly duckling K-01), which could be the reason why. The rest (the quiet operation of the K-5 & K-7) is much more your K-x, including a noisy shutter!
03-28-2013, 05:12 PM   #5
Tord's Avatar
If you go to Pentax K-30 Review: Digital Photography Review and exchange the cameras compared to the K-30, to K-x, K-5 & K-5 II you will find that not until ISO 25600 the K-x has an advantage on the others. The K-30 feels best all the way till then, with the K-5 being the worst of them all. The difference isn't big, but it is there! At low ISO I can't see any difference between any of them, neither in the shade, nor in the brightly lit areas. The K-30 might be a tiny bit softer, but does a real good job compared to its brothers and sisters ;-)!
04-01-2013, 01:14 AM   #6
QuoteOriginally posted by Tord Quote
But the K-x doesn't have ISO 25600....
I don't have the K-5 Classic, but I do have both K-x and K-5 IIs. I'm not sure about controlled tests or whatnot, but in my case of personal experience the IIs trounces my K-x at any situation, only being real close in ISO100 and 200.
04-01-2013, 05:13 AM   #7
audiobomber's Avatar
DXOMark is the only credible place for evaluating sensor performance on noise, DR and colour. All other reviews I've seen are misguided. Some are evaluating based on jpegs, which masks and manipulates real performance. Most reviews don't properly normalize to the same resolution, so higher pixel densities look worse.
DXOMark results show K-5 and K-30 are pretty much identical and SNR is superior by 1/2 stop over the K-x, normalized to 8mp. At ISO 12800 they all converge.
05-19-2013, 04:44 PM   #8
Spodeworld's Avatar
Is the 1.1 EVS difference in dynamic range for landscapes between the k30 and k5 visually noticeable in practical terms?
camera, dslr, generation, k-x, k30, k5, noise, photography, reviews, sensor
New K30 seems to have high amounts of noise? jbot Pentax K-30 & K-50 4 09-17-2012 05:26 AM
Weird grinding noise - K-x maxwolfie Troubleshooting and Beginner Help 7 08-25-2012 05:17 AM
K-X strange audio noise paranoia23 Troubleshooting and Beginner Help 3 08-16-2012 09:55 PM
X-Pro or K30/K5 goldpopper Non-Pentax Cameras: Canon, Nikon, etc. 6 07-29-2012 01:02 AM
k-x noise WDWmom Pentax DSLR Discussion 11 05-29-2011 04:40 PM
All times are GMT -7. The time now is 09:47 PM. | See also: NikonForums.com, part of our network of photo forums!
