Here are a couple quick shots with the Q. I was in the process of selecting gear for the holiday events so the main compartment is empty. The upper is used for flash gear these days - B&H TTL, Pentax AF16, and Cowboy Studios triggers plus a base plate and 4 pack of AAs. There is also an IR remote in the mesh pocket behind the flash. Hope this helps. I use the main T compartment for the K-5+18-135 combination with D-BG4 Grip. Each of the 4 main divisions will hold a 55-300 or two smaller lenses like my Limiteds with a foam rubber pad between the two lenses to protect each of them. Typically, if I am going whole hog I can carry the 55-300, Viv85, DA35, FA50, DA40 & DA70, K-Q adapter, plus have room in the last small rectangular compartment for the Q body. Extra batteries go in the front compartment along with the lens pen. If I need more space I use the SlipLock attachment points for any of 6 cases that I own that will work - I have two rectangular bags that will attach that are not padded, two P&S cases that will attach, and 2 different size lens cases that are Lowepro and several knockoffs that will work but are not as secure when attached. All-in-all it gives me a lot of flexibility and capacity in a relatively small package (until I start hanging all those sliplock bags on it
