So basically if you want to use a lenses field of view on film as a standard, then you have to multiply by the crop factor. Or you can just enjoy using your lenses without worrying about weird equivalences to make-believe standards
Most people like to think in terms of standard film (which was the most popular format for a while, but it wasn't the only format), which is where the idea of "full frame" and "crop" comes from, but these are value judgements and not very helpful technically, unless you already have a very good idea of how film would capture a projected image and want to use that to understand how it would be captured on other film/sensor formats. The Q has a much smaller sensor than Pentax DSLRs, for example, so for "equivalence" you will need to multiply it by a higher number.
