01-08-2013, 04:03 AM   #1
Advice on Cokin Filters
Hi Guys,
Since buying a Tamron 17-50 f/2.8 recently I've decided I want to invest the Cokin filter system. The Tamron is a much bigger thread at 67mm whereas the kit lens was 52mm. I'm currently in the process of selling my old filters - UV, Polarizing, ND etc and figured I'd rather invest in something like Cokin rather than keep having to buy new filters when I change lenses.
I've done some research and it seems I need the Cokin P series, I've heard a few conflicting reports that some people encountered vignetting at around 18mm with the P series but other people say you can go as low as 10mm with no issues. Can anyone verify if this is the case? I don't fancy getting the Z-Pro ones as they are a lot more expensive!
Secondly with regards to the actual filters themselves, am I ok buying some third party ones off ebay? or are these rubbish and should I get genuine Cokin ones? I'm not looking to buy any graduated filters as I typically add these in post processing. I think I'll only want polarizers and ND filters. With the ND filters, I'm looking for around a 10 stop filters - as these seem very expensive can I simply stack multiple NDs together - I think the P series holder supports up to three filters, what do you guys typically do?
Any help is appreciated.
Cheers
Alex
01-08-2013, 08:27 AM   #2
Digitalis's Avatar
you will be better off buying genuine Cokin filters, mixing off brand ones is more than likely introduce odd colour shifts - that otherwise would not be there. As for stacking ND filters together - I do not recommend this, because with each consecutive filter you stack you encourage filter flare and ghosting. Cokin GND and ND filters always tend to have a magenta cast - the stronger the ND filter is, the more likely this is to appear.
I use the Lee filter system - expensive, but plate glass filters that are immune to scratching,fading and are easy to maintain are an investment I consider to be completely worth it.
01-08-2013, 09:33 PM   #3
abmj's Avatar
I bought the Cokin P set awhile back and have been underwhelmed. It is probably my own laziness, but I have found that just putting the damn thing on and taking it back off were more hassle than I wanted to deal with while traveling. Now I mostly just take a few of the rectangular filters along and hold them in front of the lens by hand as needed. I leave the rest of the plastic fol-de-rol at home.
camera, cokin, dslr, filters, guys, people, photography, series, tamron
Ebay Cokin lookalike filters any good? voyager13 Troubleshooting and Beginner Help 12 04-24-2013 05:29 AM
Cokin filters. Tell me about quality. privateryan Photographic Technique 8 09-12-2011 11:35 AM
For Sale - Sold: Cokin Filters (Worldwide) dgaies Sold Items 11 02-23-2011 07:40 PM
Cokin-style ND filters glee46 Troubleshooting and Beginner Help 5 02-09-2011 12:45 PM
Advice on Polarizer filters kangeroo82 Pentax SLR Lens Discussion 28 05-03-2010 02:30 AM
All times are GMT -7. The time now is 04:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
