01-08-2013, 09:45 AM   #1
k-7 "white balance lock" with AE-L
Let me preface by saying I tried looking in the K-7 manual and searching around on here but I couldn't find anything as pertains to my question.
I often use the auto exposure lock and shoot in raw when capturing multiple images for photostitching. When I do this, I often batch process in rawtherapee with one preset for all images to be stitched. Unless there is a noticeable color cast I default to the camera's auto white balance setting. When stitching I sometimes notice that one or a few images have distinctly different white balances, so it seems that the auto-exposure lock does not lock down the white balance? Is this the case? Is there any way to enable such a setting? It seems like it would be a logical extension of the AE-L function...
Currently it seems the only way I'd have of going about it would be to take the time to set a custom WB prior to shooting but since I work almost exclusively in raw it seems kind of pointless to me to make any WB changes in camera...
Thanks in advance for any help!
01-08-2013, 09:50 AM   #2
Ole
Ole's Avatar
There is no WB lock. You could use a WB preset when you plan on stiching images together.
01-08-2013, 10:12 AM   #3
Thanks. That is pretty much what I figured. Is this function available on any DSLR or is there simply no demand for such a feature?
Personally, my conceptualization of AE-L is that it should be a function that prevents the camera from making any changes that will break consistency from photo to photo once activated but maybe I'm not using it the way most photographers do (i.e. lock correct subject exposure then recompose, etc...).
01-08-2013, 10:49 AM   #4
RBellavance's Avatar
Be aware that the K-7 will "fine-tune" WB presets unless custom setting "11. WB adjustable range" is set to "2. Fixed".
01-08-2013, 11:15 AM   #5
Oooo. Very good tip. Would not have realized that on my own and probably would have caused some consternation.
01-08-2013, 12:39 PM   #6
johnyates's Avatar
If you're shooting in raw all you need to do is select any other WB setting other than auto. I would use daylight, and then fine-tune in PP.
01-08-2013, 09:50 PM   #7
kkoether's Avatar
QuoteOriginally posted by johnyates Quote
I finally broke down and bought a gray card for setting white balance. Don't know why I didn't get one sooner!
10-21-2013, 08:03 PM   #8
QuoteOriginally posted by Ole Quote
WIll have to use this for shooting video too (I got here searching for how to lock the white balance for video).
The WB hunting while shooting video is really bad - quite unusable. Even with just one guy standing in front of a green screen - moving slightly.
So I just need to set the current white balance as a preset and also set the setting discussed below (no fine tuning WB) and I should be good to go.
ae-l, auto, balance, camera, dslr, images, k-7, photography, wb
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
difference between "focus indicator" with "matte field" cmrhm Pentax K-5 & K-5 II 3 07-31-2012 02:12 PM
K-x "aperture priority" records as "automatic" in meta data charlestm Pentax DSLR Discussion 3 12-05-2011 12:12 PM
People ~ K a o r i ~ " S h e W a l k A l o n e " Anucha Post Your Photos! 2 06-29-2011 10:35 AM
K-7 and metering with "K" and "M" lenses NaClH2O Pentax DSLR Discussion 17 07-18-2009 09:00 PM
All times are GMT -7. The time now is 05:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
