02-20-2008, 11:28 AM   #1
alohadave's Avatar
3 is showing up in viewfinder?
I have a K100D Super, and I'm trying to figure out something I'm seeing in the viewfinder. When I press the shutter button, I see a 3 (it is also on the top LCD screen) It's just to the left of the SR hand indicator, where the frame counter/EV indicator is.
I haven't been able to find what the 3 indicates, and it comes up in every mode when the shutter is half pressed (I have the AF moved to the Ok button).
Can anyone tell me what it means?
02-25-2008, 06:15 PM   #2
Arpe's Avatar
I beleive it means that if you hold the button down you will be able to take 3 shots, such is the pathetic buffer built into that camera. My istDs, a much older but comparable camera, shows an 8. This is turn off-able in the menu somewhere, on mine anyway.
02-25-2008, 10:58 PM   #3
QuoteOriginally posted by Arpe Quote
I wouldn't say pathetic. It's a $300 DSLR with stunning image quality. Your *ist didn't cost that, did it?
It's on custom menu under "Dsply no recdble imgs" or something like that.
It displays a 3 when shooting JPEG, yet with a Sandisk Ultra II I cant get 4 shots in sucession at 2.7fps, then about 1fps after that. If you need more camera get a K10/20D!
02-27-2008, 04:33 PM   #4
Arpe's Avatar
The camera isn't pathetic, the buffer is.
"Your *ist didn't cost that, did it?" No it cost way more, but the photos I took in the meantime are worth wayyyyy more.
02-27-2008, 05:40 PM   #5
khardur's Avatar
yeah, as was said above, that's the number of shots remaining before you fill the buffer.
You can change it to show the number of recordable images left on the memory card if you wish.
Or it won't show up at all if you're in manual mode, it will only show you how far off the meter thinks you are with your settings.
button, camera, dslr, indicator, photography, shutter
Viewfinder has metal piece showing EyeSpy Pentax Film SLR Discussion 11 04-23-2010 06:51 AM
Showing off the FA 50 macro bdery Post Your Photos! 5 07-26-2009 05:29 AM
K200D viewfinder + Katzeye VS. K20D viewfinder dugrant153 Pentax DSLR Discussion 3 07-24-2009 11:36 AM
K200D Viewfinder vs K20D Viewfinder cputeq Pentax DSLR Discussion 7 06-15-2008 11:57 PM
Gallery showing hamidlmt Photographic Technique 8 06-26-2007 09:59 PM
All times are GMT -7. The time now is 11:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
