02-21-2008, 05:12 PM   #1
External Flash
Just received my new K10D...Will my Sunpak autozoom 333 function OK??
Lew
02-22-2008, 02:17 AM   #2
Matjazz's Avatar
Judging from the trigger voltage table it won't hurt to try it your self. You won't have the PTTL mode thou...
Sometimes all you have to do is ask uncle Google.
02-22-2008, 07:58 AM   #3
I had the same question (same flash), and it wasn't an easy answer to find! Don't even bother asking Pentax because they will not give a maximum trigger voltage that is safe for their cameras, nor will they even acknowledge flashes other than Pentax brand. I tested the trigger voltage on mine, and the highest value I got was 6.5V, which should be plenty low enough. I have had some very nice results using this flash with the K10D.
Check out this thread:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/20470-opinion-expe...p-flash-2.html
02-22-2008, 08:37 AM   #4
noblepa's Avatar
Trigger Voltage
QuoteOriginally posted by Shotgun Quote
... Don't even bother asking Pentax because they will not give a maximum trigger voltage that is safe for their cameras, nor will they even acknowledge flashes other than Pentax brand. ...
Shortly after I got my K10D, in September, I sent an email to Pentax, asking about the maximum safe trigger voltage. They did reply and tell me that the max was about 25 volts. Most flashes being sold today are under 10 volts, so they should be safe.
The problem is, if you don't want to spend an arm and a leg for a P-TTL flash, you need an old-fashioned auto-flash. Very few of those seem to be made today, except low end, low power flashes. That's why Vivitar put the old 285HV back into production.
I recently read somewhere that the PC socket in the K20D has builtin circuitry to protect the camera agains high voltages from studio flashes. It seemed to imply, since it specifically mentioned this in the context of the PC socket, that such protection was not built into the hotshoe.
02-22-2008, 08:59 AM   #5
QuoteOriginally posted by noblepa Quote
You got farther with Pentax than I did, I guess. Here's what they told me:
"Maximum trigger voltage is a specification that Japan has never released. Pentax flashes, even the older ones, do not pose any risk for use on our cameras. Since we cannot guarantee non-Pentax made flashes will be compatible or safe to use on the cameras we always recommend you use a wein safe sync with them to protect the camera."
02-22-2008, 09:07 AM   #6
That's what they told me, too. I did get a safe-sync, and I think it's a good thing to have. The most accurate flash I have is a Metz 45CT-5, a wonderful piece of gear. I'm pretty sure you can still buy a Sunpak 444D, which is pretty powerful, brand new from B&H or Adorama, for about a hundred bucks. Nice flash, too. I have a Sunpak 333 and I'm sure it would work fine on the K10D. I'd use the safe-sync just to make it safe, though. If you fry your camera with an off-brand flash, Pentax will not honor the warranty.
camera, dslr, photography
K7 external flash DonX Troubleshooting and Beginner Help 2 05-12-2010 09:16 AM
using the external flash? strictlypentax Flashes, Lighting, and Studio 3 04-24-2010 01:30 PM
need help with my external flash Death2man Flashes, Lighting, and Studio 2 01-17-2010 01:17 AM
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
external flash with k-x grakenverb Pentax DSLR Discussion 3 12-25-2009 05:25 PM
All times are GMT -7. The time now is 11:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
