01-21-2013, 09:21 PM   #1
Pentax K-m flash issue
Hi, the problem when I wanna shoot in less time then 1/125 (it means that I wanna shoot in 1/250, 1/1000...). The camera is not transmitting any signal to external flash. I've got this checked for 100% with my external transmitter and receiver. Until 1/125 camera sends signal to transmitter.
Please help.
01-21-2013, 09:43 PM   #2
VisualDarkness's Avatar
You pass the max sync speed, nothing to do about it. Why do you want to shoot with a higher shutter? Flashes most often freeze the subject anyway.
01-22-2013, 01:56 AM   #3
You should be able to sync at 1/180, what wireless triggers are you using?
01-22-2013, 07:51 AM   #4
QuoteOriginally posted by VisualDarkness Quote
Is this sync maximum on other pentax dslr cameras too ?
I wanna shoot outdoor portraits and i need to control ambient light with shutter speed.
01-22-2013, 07:54 AM   #5
QuoteOriginally posted by elliott Quote
Nope, it is at 1/125. I dont know why u ask about trigger if problem is in camera. I tried flashlight too, not working. This is the trigger : PT 16 16 Channels Wireless Flash Trigger for YONGNUO YN 460II YN 468 YN 560 | eBay
01-22-2013, 08:12 AM   #6
I asked about the trigger because the Yongnuo RF-602 has a problem syncing beyond 1/125 on a Pentax body without a modification, those are the triggers I use so it sounded familiar. I don't think those older ones had the same problem though.
I can't think of any reason why you wouldn't be getting full 1/180 sync with a flash on the camera, unless the camera is broken anything up to 1/180 should definitely work.
01-22-2013, 08:16 AM   #7
Lowell Goudge's Avatar
There are a couple of things that may limit the flash sync. First, what are the exposure steps selected, depending on 1/2 or 1/3 stop can change the maximum sync speed reached because the maximum speed may not be a direct increment
Also make sure there is nothing like rear curtain sync selected, this restricts sync to 1/2 leading curtain sync.
01-23-2013, 08:24 AM   #8
I will check exposure steps. What is rear curtain sync ?
01-23-2013, 09:36 AM   #9
QuoteOriginally posted by mmand Quote
It makes the flash go off at the end of the exposure rather than at the start.
camera, dslr, flash, photography, transmitter
Weird white balance issue on my K-5 with flash Codazzle Pentax K-5 & K-5 II 3 01-02-2013 04:04 PM
K-5 and Off-camera Flash Sync Issue stevelink Pentax K-5 & K-5 II 10 12-26-2011 05:51 PM
Issue with Pentax ZX-M Jakedm80 Troubleshooting and Beginner Help 3 03-29-2011 10:09 AM
Issue with stop down metering - 50mm SMC Pentax-M with K-X harry63 Pentax DSLR Discussion 3 01-14-2010 10:33 PM
AF540FGZ flash issue - M. Zoom all the time dugrant153 Flashes, Lighting, and Studio 6 11-10-2007 12:36 AM
All times are GMT -7. The time now is 08:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
