02-24-2008, 01:43 PM   #16
If that's the case, is there an easy workaround? How should I shoot to get a decent properly exposed photo?
02-24-2008, 02:12 PM   #17
Eaglerapids's Avatar
Check your histogram after taking a shot. It will tell you if you're way underexposed.
02-24-2008, 02:29 PM   #18
I agree with Gimbal - when it's dark enough, you're on your own.
I've got an impression that when the exposure times go above one second or so, the camera is not able to calculate correct values.
Also, there might be bright spots in the picture (house lights, street lights, moon) which confuse the exposure. You could try turning on spot metering instead of evaluative and pointing the metering point away from light sources.
As you noticed, exposure compensation of +3 might not be enough at night.
I've always gone with trial and error when shooting at dark :-)
02-24-2008, 06:43 PM   #19
Stratman's Avatar
Do you have noise reduction enabled?
02-24-2008, 07:05 PM   #20
The K10D can do a pretty decent job in really low-light situations - 10, 20 second exposures in Manual mode. I tried out some shots with moon-light a few weeks ago.
But you are on your own - manual focus, manual exposure without guidance. Beyond 2 secs, I think, the metering can't suggest to you what is the appropriate exposure.
02-25-2008, 01:13 AM   #21
Additionally, don't hesitate to crank up the ISO to 800 for long night exposures; I use it with NR enabled and it is worlds better than my old Nikon when it comes to noise and NR softening at that ISO.
02-25-2008, 01:30 AM   #22
After asking related questions here a short time ago I was informed that keeping the ISO low and using longer exposures should give the lowest noise in night exposures.
My latest (Feb) pic by the light of the full moon seems quite noise free to me.
It was exposed for approx ten minutes at ISO 100.
02-25-2008, 05:20 AM   #23
distudio's Avatar
QuoteOriginally posted by kittykat46 Quote
-25 C is far below the recommended operating temperature of the K10D (0 C to 40 C- page 3 of the manual). You have shown that it does operate at such low temperatures, probably won't produce good pictures, though.
The low temperatures limit would likely be set to ensure correct operation of the LCD displays and lubricants, sensor noise performance should improve with reduced ambient temperature.
02-25-2008, 07:12 AM   #24
Tom M's Avatar
Any long exposure shot should be taken at ISO100 in my opinion. The K10D does extremely well at multi-minute exposures at ISO100. I have 3 minute long exposures with zero noise.
02-25-2008, 09:34 AM   #25
I ordered a wire switch for long exposures. With it I can use bulb mode and over 30s exposures. The 30s that is the camera maximum is obviously way too short for moonlight shots. Funny that they don't build long exposure timers in these. (I think nobody else does either) Would be very easy to do.
03-03-2008, 12:00 AM   #26
pixelsaurus's Avatar
QuoteOriginally posted by Smoothster Quote
In ancient times,manufacturers use to have a "T" setting as well as "B". First shutter push opened and locked the shutter, 2nd push closed it. No need for those horrible little lock screws on cable releases. Why it was ever removed has baffled me for some 40 years.
03-03-2008, 03:05 AM   #27
PW Pix, that 10 minute, ISO 100 shot is remarkable. I'm going to have to pick up a cable release and give that technique a try, as it is noticeably cleaner than my shorter, but higher ISO, exposures. Gad, sensors have come a long way in the past few years!
03-03-2008, 04:01 AM   #28
Yes Christine, I made January's full moonlit landscape at ISO 400 and approx 2 mins exposure, the Feb one at ISO 100 is much cleaner.
albums, aurora, camera, dslr, exposure, janne, noise, photography, picasa, shots, web
Pentax K10D long exposure noise reduction when shooting RAW? Robert S Donovan Pentax DSLR Discussion 30 08-19-2013 11:42 AM
Long exposure camera noise Alex00 Pentax DSLR Discussion 2 02-27-2010 05:55 AM
long exposure noise? slow2focus Troubleshooting and Beginner Help 9 12-16-2009 09:24 PM
Which is worse for noise? Long Exposure or High ISO boodiespost Troubleshooting and Beginner Help 7 12-10-2009 07:57 AM
K-x long exposure noise? er1kksen Pentax DSLR Discussion 4 11-06-2009 01:17 PM
All times are GMT -7. The time now is 04:12 AM. | See also: NikonForums.com, part of our network of photo forums!
