02-05-2013, 01:09 PM   #1
K-30 & Lenses - what to look for
Hello All,
I'm starting to look for new lenses, but can't figure out the reasons why the K mount lenses are different. The Pentax site says k mount will work with an adaptor or limitations. What does this mean? Do I need an adaptor or will I not have auto focus (or something like that)?
I guess my question is, what lenses will work with my K-30.
Thank you.
02-05-2013, 01:15 PM   #2
Saxplayer1004's Avatar
You will be able to use any K-mount lenses.
You can use M42/Screw mount lenses with the appropriate K-Mount adapter. You won't have AF with non AF lenses obviously, and with M lenses you won't have auto aperture, but any K-mount will mount straight on
02-05-2013, 01:21 PM   #3
QuoteOriginally posted by Mlcinema Quote
Hello All,
Thank you.
See here:
Pentax Lenses - Pentax Lens Reviews & Lens Database
Everything under the first 2 red headings will work w/o an adapter- that's hundreds of lenses!
See also:
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
The Pentax Camera Lens Compatibility Chart
02-05-2013, 01:29 PM   #4
Excellent. Thank you.
What does "The lens/body combination works with limitations in metering." mean with the yellow check circle? ( The Pentax Camera Lens Compatibility Chart )
02-05-2013, 01:36 PM   #5
If you are able to use manual focus lens. then get a M42 lens adaptor . Such as the Carl Zeiss 35mm 2.4 is a legend.
they are sharp and good color rendering for $ 250 approx. other M42 as well.
02-05-2013, 02:56 PM   #6
kcobain1992's Avatar
"Limitations in metering" means that you have to press a button.
02-05-2013, 03:12 PM   #7
boriscleto's Avatar
The KAF2 mount in Pentax DSLRs is "crippled". This means that the aperture linkage that allowed K and M series lenses to communicate what aperture they were set to to the camera has been removed. The only way for the camera to get a meter reading with these lenses is to stop down the aperture so the meter can record how much light is coming through the lens. On the K-5 this can be done by pressing the power switch to the DoF preview position or pressing the Green Button. On the K-x / K-r you can press the Green button or the AV+/- button etc.
02-06-2013, 12:02 AM   #8
bassek's Avatar
Hi!
Welcome to the forum. The database will guide you towards LBA.
Assumíng you have the kit lens, here are a few tips:
Any of the F-series lenses are a good buy (except maybe the F35-80), and can be had for a reasonable price.
The M-series 50/1.7 is very good and affordable, an alternative is the K-series 55/1.8 which is heavier and slightly larger. Should be had for 50-100 USD each.
If you want metering (overrated, the green button works fine) there is the A50/1.7, albeit slightly more expensive. These are manual lenses, but they will teach you the basics.
There is a cure for LBA, but neither public healthcare or any insurance will cover it.
Seb
02-06-2013, 12:58 PM   #9
Thank you all for the info.
adaptor, camera, dslr, k-30, lenses, photography
What to look for in second hand k5 vetty Pentax K-5 & K-5 II 4 11-25-2012 10:33 AM
Used K10D , what to look for? Reaper Pentax DSLR Discussion 9 06-07-2012 03:14 PM
Buying a used 645 - What to look for? germar Pentax Medium Format 10 06-01-2012 10:31 AM
What to look for or test in new DA* 16-50 Verglace Pentax SLR Lens Discussion 16 02-06-2012 06:34 AM
What to look for in buying used lenses? KeithM2 Troubleshooting and Beginner Help 15 09-13-2011 08:06 AM
All times are GMT -7. The time now is 08:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
