02-25-2008, 01:34 PM   #1
K10D B&W RAW capture?
Help I have mislaid my manual.
Is it possible to set the K10D to capture black and white RAW images? or indeed black and white JPEGs?
Or....can images only be converted post capture using computer software?
Thanks in advance.....
Simon.
02-25-2008, 01:52 PM   #2
Miserere's Avatar
Why would you want to do this? Having control over the B&W conversion process after you've taken the shot is one of the great advantages of digital. That, and not having to lug around a whole bunch of colour filters.
02-25-2008, 04:17 PM   #3
Agreeded why is this feature desireable. Just turn down the saturation in any RAW converter. I know RAW Developer and Lightroom have dedicated functions for BW and Sepia like duotone pictures. You can even do it on groups of photos!
02-25-2008, 04:38 PM   #4
Ivan Glisin's Avatar
QuoteOriginally posted by tybeck Quote
That would give sub optimal results. First, with channel mixer in Photoshop or B&W tool in Lightroom is the way to go. Second, good B&W requires pure black and pure white details so levels/curves are a must to achieve that. Default desaturation without any additional correction results in a flat and boring result, what I call G&G photograph (Gray & Gray). Third, increasing local contrast helps a lot (USM 10-20%, 50px in Photoshop, or 25-50% "Clarity" control in Lightoom).
Result of applying the steps outlined above:
02-25-2008, 09:16 PM   #5
QuoteOriginally posted by gostwick Quote
Simon.
Back to the OP...it isn't possible to set a direct B&W capture in either RAW or JPEG. There is an in-camera B&W JPEG processing option (in Menu>Playback>Digital Filters, IIRC). But, as everyone above has pointed out, it is usually better (= more control over the final appearance) to convert your color JPEGs to B&W in pp software. It is necessary to do so when converting RAW files.
02-25-2008, 10:22 PM   #6
There is a way to do some kind of B&W, ending up with a B&W image from RAW with a bit more detail, but it involves setting some very confusing parameters for demosaicing on dcraw (command line), and I don't remember where I saw that - plus you get some weird artifacts.
Anyone seen that? Browsed pages and pages of search and couldn't find it.
02-26-2008, 12:13 PM   #7
Muchly thanks for the info everybody.
I'm using Elements 6 and so will try to get conversant with the best methodology using that software.
(I'll give it a go)
Simon.
gostwick on Flickr.
02-26-2008, 08:27 PM   #8
Enjoy the software learning curve, Simon! It's just part and parcel of this brave new world of digital photography, where the computer is both a replacement for the darkroom and an extension of the camera.
camera, dslr, images, k10d, photography
What RAW capture software do you like? quantum Digital Processing, Software, and Printing 20 07-18-2009 07:57 AM
Testing RAW software - Question about Capture One YJD Digital Processing, Software, and Printing 9 01-03-2009 08:05 PM
Camera settings and RAW capture gamgee Pentax DSLR Discussion 4 06-22-2008 02:45 AM
K10 Raw Capture in User Mode josh Pentax DSLR Discussion 3 02-08-2008 03:40 PM
Capture One with raw elnero Photographic Technique 2 01-27-2008 01:51 PM
All times are GMT -7. The time now is 12:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
