02-14-2013, 06:05 PM   #1
DA* Lens and Full Frame
I have searched in this forum on the topic of usability of DA/DA* lenses on a Full Frame Pentax and it appears that they will not be useful as huge vignetting occurs. Considering the confirmed rumor that Pentax is working on a Full Frame DSLR does it make sense to buy any DA/DA* lenses anymore? Should we be only looking for FA lenses in order to be able to use them in future Full Frame body? Thanks.
02-14-2013, 06:13 PM   #2
Digitalis's Avatar
QuoteOriginally posted by godavari Quote
Apparently you didn't search properly, many DA and DA* lenses are quite capable of covering full frame. Vignetting isn't exactly the end of the world, it is easily correctable in post (to an extent) lenses like the DA40mm f/2.8, DA70mm f/2.4, DA35mm f/2.4,DA50mm f/1.8, DA*55mm f/1.4, DA 100mm f/2.8 MACRO, DA*200mm f/2.8, DA*300mm f/4. are all quite capable of being used on a FX format sensor.
02-14-2013, 06:15 PM   #3
apparently you didn't search properly, many DA and DA* lenses are quite capable of covering full frame EG: DA40mm f/2.8, DA70mm f/2.4, DA35mm f/2.4,DA50mm f/1.8, DA*55mm f/1.4, DA 100mm f/2.8 MACRO, DA*200mm f/2.8, DA*300mm f/4.
Right. I should have more specific. While there are few lenses that work well many lenses do not. I am wondering about DA* 16-50 f/2.8, DA* 50-135 f/2.8 and DA* 60-250 f/4.
02-14-2013, 06:19 PM   #4
Digitalis's Avatar
Well that is different, many prime lenses in the pentax lens line up are derived from prime lenses that were originally designed to cover FX format - the DA series zoom lenses are often designed to be more compact and make use of the smaller image circle required to cover APS-C in order to keep the size of the lenses down. Allegedly Pentax is considering using Tamron and Tokina to develop a new line of FX zoom lenses for the upcoming FX format camera, they will probably be manufactured by Tamron and/or Tokina and designed by Pentax.
02-14-2013, 06:26 PM   #5
stormtech's Avatar
In the lens section of the forum -
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/31629-da-lens-...ts-thread.html
02-14-2013, 06:41 PM   #6
Those lenses (especially the f/2.8 models) are very good lenses for right now. There's really no replacement for them if you need higher quality AF zooms on APS-C, which is why I have 2 of them. Other than that, I have all FF compatible lenses, except at the wide end (DA15 and DA10-17 FE).
02-14-2013, 06:49 PM   #7
I see. I have two DA* lenses already that work great. I have couple of Sigma lenses. Before buying a lens I wanted to know if they can be useful in future. It appears that I need to wait.
02-14-2013, 07:00 PM   #8
stormtech's Avatar
If this is all about a Pentax full frame digital camera, you'll have a long wait if it even materializes at all.
02-14-2013, 07:30 PM   #9
Banned
Let me give a shameless plug for B&H...
Click on their main B&H link/page, then - under the photography category click on lenses, then - SLR lenses, then - the Pentax (otherwise known as Pentax PK, but not on this site) option; which should show there are some ninety plus current new lens options available, then - under lens format click on the full frame option - which will then eventually show some fifty plus existing options.
Or take this one step link...
SLR Lenses| B&H Photo Video
02-15-2013, 07:49 AM   #10
QuoteOriginally posted by Medium FormatPro Quote
Thanks for the link Medium FormatPro. I was looking at Pentax DA* 60-250 f/4 and that comes closer to this zoom is Sigma 70-200 f/2.8 in terms of focal length but still falls short. I not only like the reviews of 60-250 but its zoom as well when compared to 70-200 it offers more range both at zoom in and zoom out. As the price is high and if I get it, I wanted to make sure that I can use it for an extended period of time.
02-15-2013, 08:02 AM   #11
The 60-250 is an amazing, amazing lens. I will also be going FF if/when it is ever available on Pentax, but I will not likely sell the DA* zooms. My ideal system would be to have two cameras - FF and APS-C so I take take advantage of the best of both formats. Also, a lot of FF cameras allow you to go into a crop mode - I know the D800 does this. So instead of having a 32mp FF image you have a 16mp crop and you can still use your crop lenses. We don't know if a Pentax FF will offer that "crop" mode, but if you are likely going to keep your crop camera after purchasing FF then this wouldnot be a wasted purchase.
02-15-2013, 08:44 AM   #12
I think the DA *55, 60-250, 200 and 300 are full frame compatible (60-250 has some vignetting, but not bad). 16-50 and 50-135 would need cropping to allow them to be used.
02-16-2013, 10:08 AM   #13
It will be interesting to see how these DA lenses perform on FF. I'm confident... It's one thing to not vignette but it's another thing to survive the pixel peeping especially in the corners.
FF really isn't an issue for me though since I have neither the money nor the skill level to blame the K-5 for any bad photos. Of course if I had the money I would buy it...
04-23-2013, 08:55 PM   #14
LXNights's Avatar
They might come out with a new lens line upon delivery of FF, lenses that can be used on both APS-C and FF. Maybe the new camera can use both formats.
04-24-2013, 04:29 AM   #15
Sigma 70-200 f/2.8
All the Sigma 70-200's are FF lenses. Any 'DG' Sigma lens is FF.
camera, da* lens, dslr, frame, lenses, pentax, photography
DA lenses on Full Frame: Test Shots thread falconeye Pentax Lens Articles 523 11-28-2018 03:31 PM
Lens compression effects on APS-C and full frame tyronfall Pentax SLR Lens Discussion 56 05-14-2012 08:17 AM
Full frame Lens vs DA lens(APS) bobmaxja Pentax SLR Lens Discussion 8 04-17-2010 12:03 PM
Full Frame lens vs DA & crop factor comparison... JayR Troubleshooting and Beginner Help 4 03-02-2010 09:15 PM
DA vs FA Limited and the question of full frame digital 8540tomg Pentax SLR Lens Discussion 27 11-29-2008 10:07 AM
All times are GMT -7. The time now is 08:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
