03-03-2013, 06:11 AM   #1
old4570's Avatar
Split screen
Anyone swapped in a split screen to help with manual focus lenses ?
I used to really like these in the 35mm days
03-03-2013, 06:14 AM   #2
Jonathan Mac's Avatar
I have a Katzeye one in mine. Accurate manual focusing on a DSLR is virtually impossible without one. You'll find quite a few other people have done the same, mainly so that they can use old manual focus lenses. I think very few go cak to a plain screen after trying the split prism or other alternatives.
03-03-2013, 06:33 AM   #3
Anvh's Avatar
They will work fine, only the light meter will be off a bit.
03-03-2013, 07:08 AM   #4
reeftool's Avatar
I have a Katz Eye in my K10D which I purchased after first buying a cheapie offf Ebay. Others have had good luck with the Ebay screens, I didn't. At around $25, they're worth trying. The only metering that gets affected is spot metering. I find it essential for using MF lenses. Having 2 camera bodies, my K10D has become "manual glass camera" which is why I haven't added one to my K5 yet.
03-03-2013, 07:20 AM   #5
Lowell Goudge's Avatar
I have 2. Both are from Jin finance, one is a single diagonal split, the other a dual diagonal split. The dual split seems rose accurate on focusing because it displaces a "slice" that is quite obviously misalligned when out of focus
03-03-2013, 12:34 PM   #6
tclausen's Avatar
Sounds very interesting, got a link to where to get that screen?
I have half a mind of seeing if an *istD can be so converted....
03-04-2013, 01:38 PM   #7
hongzhibin1987's Avatar
I swapped the one on my old K7.
Works perfect, and had no problemo of with EV.
03-04-2013, 04:06 PM   #8
old4570's Avatar
I ordered one for my istD to try ..
Check out Ebay
03-04-2013, 04:43 PM   #9
ivanvernon's Avatar
One of my 20-D cameras has a Katz-Eye split screen, and it really helps a lot with focus combined with the viewfinder focus emblem. I keep this 20-D set up for manual lens, A50mm 1.7, Auto Sears 135mm 2.8, Helios 44K-4, and others. I do not have any experience with other brands of focussing screens, so can speak only of the Katz-Eye, and I can definitely recommend it. My technique is to use the split-screen to get as near to focus as possible, then turn the focus ring very slowly while watching for the viewfinder focus emblem to pop in. While standing for hand-held shots, I sometimes do not turn the focus ring, but instead move my entire body slightly forward or backward to bring the camera into focus, sort of like locking a macro lens and moving to or from the subject to attain focus.
03-04-2013, 05:36 PM   #10
QuoteOriginally posted by tclausen Quote
Try this
Dual Split Image Focus Screen 4 Pentax K10D K20D ist DS | eBay
The K10D screen and *istD screen are interchangeable. I have this in my *istD
If you are at all mechanically adept and can work with s,all items it takes about 2 minutes to change. Just get a clean AA, some tweezers and read the instructions about changing focusing screens, or search here on the forum for clues
03-04-2013, 11:08 PM   #11
DeepThrob's Avatar
I got my first manual lens for my k2000 and I found that I couldn’t focus it so I bought one of those $20-dual split-ebay viewing screens. I didn’t do a good job installing it and took a couple of tries.
It seemed like I was putting a lot of torque on the latch and I wasn’t sure if the shim was to stay in or (as I read somewhere) go. I also had an issue with dried out rubber around the latch crumbling after I poked it while opening the latch for the third time.
It works well, but I got some dirt on top and scratched the bottom some. I’ll do a new one soon.
Attached are some tests. I had strange lighting and I adjusted levels. my conclusion is that it’s good enough for 3.5 but front-focusy @ 1.7
Before I get the new one, I want to try shimming this one with tape to find where it’s optimal.
03-05-2013, 02:43 AM   #12
jkomp316's Avatar
I tried one for about a week. It made it easier to focus on fixed objects, but harder to focus on moving ones.
03-05-2013, 02:25 PM   #13
Moderator PEG Judges
Kerrowdown's Avatar
Katz eyed all mine and use the viewfinder magnifier eyecup O-ME53 too.
03-05-2013, 04:25 PM   #14
old4570's Avatar
Yes , I have a magnifier as well ...
03-06-2013, 01:51 AM   #15
The best focusing screen I have tried so far is the EE-G (newer one is EE-S) from Canon.
Had the K3 screen before but it affected spot metering and was a bit off and had to be shimmed to be good enough (and there are quite a few reports of this).
Theres a thread going about in this forum on the EES screen.
Perhaps its worth it to have a look at it before you spend the money.
camera, dslr, photography, screen, split
K-1000 split-screen for DS2? jt_cph_dk Troubleshooting and Beginner Help 8 04-09-2011 05:48 PM
Focusing screen issue. Split-screen out of whack? marcdsgn Troubleshooting and Beginner Help 12 02-24-2011 04:06 PM
For Sale - Sold: Katzeye Optics Split-Screen Focusing Screen for K-7 (CONUS) porterHause Sold Items 2 12-07-2010 05:08 PM
For Sale - Sold: Minolta X-700 Focusing Screen (for you to cut your own split screen) frank Sold Items 3 09-24-2009 10:08 PM
Seeking advice on focusing screen (split screen) for K200D Ari Freund Pentax DSLR Discussion 8 07-31-2009 03:00 AM
All times are GMT -7. The time now is 01:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
