03-09-2013, 05:32 PM   #1
old4570's Avatar
Calibrate Lens
Hmmm , just read something about calibrating a lens , is there a DIY guide ..
03-09-2013, 06:16 PM   #2
I haven't personally done it, but there is quite a good explanation of the process here ---> Lens Calibration Explained
03-09-2013, 06:22 PM   #3
I think lens calibration is sort of a misnomer- after all, it's the camera AF settings that are being adjusted. Here's our guide to doing it:
Fixing Front and Back Focus - Introduction - PentaxForums.com
03-09-2013, 07:46 PM   #4
old4570's Avatar
Thank you ...
03-10-2013, 06:00 AM   #5
When you say "calibrate lens" do you mean you have an issue with front or back focus? If so, and if you have a camera that has live view, this is the best method I've seen:
AF microadjustment for the 1Ds mark III, 1D Mk3, 5D Mk2, 7D, 1D X
03-10-2013, 07:30 AM   #6
old4570's Avatar
Im testing the lens , and seeing what works , sometimes the focus is soft , but that might be me , a tripod would eliminate a lot of guess work , I just wanted to see what the cure might be if its the lens / camera not working well together .. ( could be me shooting free hand )
03-10-2013, 11:35 AM   #7
The technique I find that works best is based on the method in the link from MPrince. Instead of using a tripod and shifting to manual focus I hand hold the camera and auto focus on the pattern. I then move towards and away from the computer screen until I obtain maximum moire and make the adjustment based on whether I'm closer or further away, then retest to confirm the adjustment. I have found that all of my Pentax lenses were good and that only one Tamron lens needed to be adjusted. I hope this helps simplify your calibration process.
camera, dslr, lens, photography
Any hope to calibrate monitor? thechumpen Digital Processing, Software, and Printing 42 10-14-2013 09:22 AM
What lighting conditions do you do to calibrate your lenses? LeDave Pentax SLR Lens Discussion 3 07-30-2012 12:04 PM
How to Calibrate Your Monitor RioRico Photographic Technique 24 02-17-2012 08:34 PM
Focus test with split screen-Do I need to calibrate? GibbyTheMole Pentax DSLR Discussion 4 02-25-2011 06:56 PM
How to calibrate a lens if not on K-7 or K20D? bymy141 Pentax DSLR Discussion 8 05-24-2010 04:22 PM
All times are GMT -7. The time now is 01:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
