Originally posted by jjfdvm72 Lowell Goudge -
Does the filter size equate to the apperture of the lens? I know the apperture is measured inside the lens, but your comment seemed to equate the larger the front of the lens, the bigger the apperture (which would make sense to me...)
Not directly on all lenses, that is why I qualified it to telephotos.
Apature (i.e.f2.8, F4 etc) is a mathematical ratio of focal length over diameter.
On telephoto's the filter size is the limiting factor. for example a 200mm lens with a 77mm filter can be AT BEST F2.6 but only if the opening is 77mm. In fact the maximum opening at the front of the lens is a little smaller, hence F2.8. This works well above 100mm, My 135 F2.5 has a 50mm filter, the math suggests maximum apature of F2.33
On shorter focal lengths as field of view increases, the dependance on apature and filter diverge, because the finter diameter is the size it needs to be to avoid vignetting and is usually very large in diameter relitive to what is needed for the F stop of the lens.
I use the filter size on tele lenses as a way of defining the light gathering capability. for example, my 300mmF4 has a 77mm filter, and I can add the 1.7x AF TC to it to get 510mm. This works very well for me. If someone suggests that I get a BIGMA, the filter is only86mm in diameter. and in reality is so close to my combo in size the difference is less than 1/2 stop. My own view is that it is not worth it to me to get the BIGMA for a 1/2 stop benefit at 500mm. Now if it were F4.5 (112mm filter) I would be interested.
