03-29-2013, 06:42 AM   #1
k-30 vs k-5 low light street/city, landscapes and astro
Really tempted by a 2nd hand body upgrade. My K-7 is great when the light is good. But for night street and astro it does seem more challenging - especially as my only vaguely fast lens is the FA 35mm f2.
Just trying to figure out if the K-5 is going to have a significant advantage for Astro and low light city shots.
Astro a lot of the image will be very dark, so perhaps the 12 bit vs 14 bit here wont matter much, no shadows to be thinking about.
Night city from a distance again shadows might not matter much.
Night city close to the action, shadows probably will matter.
I don't do much pp, partly because of time, I also use Linux 95% of the time (but can boot into windows on same machine) and don't own Photoshop/Lightroom etc and software like that. However as I get better the pp side might come into play a bit more. Then if I'm looking back at a load of 12 bit images I wonder if it'll bother me. But then if its exposed properly it won't even be an issue perhaps.
The thing is the pictures from the k-30 seem very good. Otherwise this would be a non-debate. I'd miss the K-7 top lcd, but perhaps I'd learn to live without. The AA battery ability might be handy as well as saving 200g or whatever. Although I do like the reassuring metal construction and weight to hold of the K-7.
White k-30 body though, in the dark in a field (for astro) might slightly easier to spot that a black K-7,K-5
03-29-2013, 07:28 AM   #2
Anvh's Avatar
QuoteOriginally posted by Conqueror Quote
That's actually the part where you could see a visible difference
03-29-2013, 08:00 AM   #3
QuoteOriginally posted by Anvh Quote
Yes thinking about it, a lot of the image might have darker areas - but these are areas which aren't completely dark.
03-29-2013, 08:14 AM   #4
I can't see one iota of K-30/K-5 difference in the -5EV underexposed recovered RAW images in the K-30 review Pentax K-30 Camera Review - Image Quality - PentaxForums.com
03-29-2013, 12:09 PM   #5
VisualDarkness's Avatar
I bet they are about the same, with slight pros and cons for each camera.
03-29-2013, 12:31 PM   #6
Anvh's Avatar
your indeed correct.
@Steve,
sensor is linear device, in the highlight it capture more type of shades then in the shadows. having more bits mean the accuracy increase. in the highlight that is already pretty good but in the shadows that precision might become visible. doesn't mean the dynamic range is increased but the accuracy could be.
03-29-2013, 01:30 PM   #7
I might be nit picking here.
The 14 bit and silent shutter are the main thing in favour of the K-5. Yes the top LCD is good to have but I might learn to live without it.
Quite how much I will notice the lower bit depth is hard to say. As the k-30 looks very close indeed in many situations.
Just found an interesting doc on this bit depth for astro...
http://www.stark-labs.com/craig/resources/Articles-&-Reviews/BitDepthStacking.pdf
03-30-2013, 12:18 AM   #8
It looks like the K-30's end result from 12 bits is much the same as the K-5's 14 bits because of noise randomisation.
03-30-2013, 02:19 PM   #9
This decision may be on hold for some time. Went for a DA 15mm (as I thought build the glass up first - I have no wide).
astro, bit, camera, city, dslr, k-30, k-7, light, matter, night, photography, shadows
New Firmware For K-01, K-30, K-5, K-5 II, K-5 IIs, K-r Adam Pentax News and Rumors 63 02-18-2013 02:04 PM
K-x vs. K-5 Low light, High ISO Rating olivemike Pentax DSLR Discussion 38 06-16-2012 01:02 AM
Low light - K-x vs K10d The Jannie Pentax DSLR Discussion 12 01-12-2012 09:55 AM
K-5 vs Nikon Autofocus lock in low light! NOT talking about speed. haassaasin Pentax DSLR Discussion 27 10-30-2011 11:34 AM
K-5 Low light/ High ISO dpreview vs dxo mark conflict vodanh1982 Pentax K-5 5 10-07-2011 02:52 AM
All times are GMT -7. The time now is 07:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
