03-31-2013, 05:54 AM   #31
audiobomber's Avatar
QuoteOriginally posted by Louicio Quote
K-01. It's a manual lens dream.
I like my K-01 but it has its limitations. There's nothing in still photography that a K-01 does that a K-30 doesn't. They use the same sensor, contrast detect system and focus peaking. The K-30 adds dual control wheels, weather-resistance,100% coverage pentaprism OVF, phase detect and faster raw shooting.
03-31-2013, 06:05 AM   #32
Louicio's Avatar
QuoteOriginally posted by audiobomber Quote
I like my K-01 but it has its limitations. There's nothing in still photography that a K-01 does that a K-30 doesn't. They use the same sensor, contrast detect system and focus peaking. The K-30 adds dual control wheels, weather-resistance, a 100% coverage pentaprism OVF, phase detect and faster raw handling.
Duly noted. I hadn't considered raw handling but if not needed the K-01 is much cheaper.
I really like the K-01 has all the right equipment to make using manual lenses much easier and user friendly. The K-30 also would have the same equip so I see your point.
03-31-2013, 01:05 PM   #33
Thanks for continued discussion... its providing some great insight.
Much to think about. I am leaning towards the K30 still... but with the K-01 in the back of my mind. Since the K30 is a current model camera, I'll probably just keep an eye out until a good low priced used one hits ebay.
BTW... I have an LX in great condition. Yes... I agree... probably one of the all time best SLRs ever made.
03-31-2013, 07:07 PM   #34
PPPPPP42's Avatar
Something you might want to consider is just leaving the M42, K and M lenses in the film corral and using only A lenses on the DSLR's.
Being able to just roll the front and rear dials in M mode to set aperture and shutter speed with normal constant wide open metering is a crap ton easier and faster and would eliminate half the debate.
If you learned to properly operate a film camera the original K5 used is best for you as most of the stuff improved after that would be a useless feature but its low light performance is super handy. K5's are dipping down into the sub $600 range now used.
I am using a K20D with a katzeye screen for manual focusing until the replacement for the K5II comes out and then I will buy an original K5 as the price should have been shoved down to at least $500 if not less.
04-01-2013, 08:19 PM   #35
Louicio's Avatar
QuoteOriginally posted by PPPPPP42 Quote
Thats why the K-01 (or the K-30 in live view) is a manual dream. With a manual lens, stop down metering will work Av for instance because the sensor is used to determine the amount of light.
04-01-2013, 10:14 PM   #36
Since you have M42 lenses, look into a old Canon 5D or 5DII with the focusing screen changed out for a EE-G/EE-S focusing screen which is optimized for f2.8 and faster lenses.
It meters the lenses in Av mode.
Clunky interface but may actually be a nice thing being almost all manual in operation.
But clearly a very old sensor that has poor DR imo compared to almost anything circa 2011.
Can't work with K-mounts unless you butcher the aperture lever, so I won't even want to talk more about it.
Otherwise, the options are K30 or K01.
K30 - better handling and overall performance over K01. DSLR interface + OVF; Comes with focus peaking too for ease of MF, but there is a lag between shutter press and actual shutter release due to the mirror mechanism, so suitability depends on your use and subject.
K01 - cheap and faster shutter reaction in LiveView due to it not having a mirror mechanism.
*ist, bodies, body, camera, dslr, gx-1l, k-mount, k10d, lenses, pentax, photography, viewfinder
A german Pentax Q user with a weakness for manual lenses GoldMark Welcomes and Introductions 4 01-10-2013 09:50 AM
Best Pentax body for manual focus lenses eagle_fly Pentax DSLR Discussion 13 11-16-2011 10:37 PM
Suggestions for an AF body. wacrider Pentax Film SLR Discussion 6 07-10-2011 11:00 AM
looking for a second body - suggestions? nobbsie Pentax DSLR Discussion 13 09-28-2009 06:52 AM
Just got an *istDS, looking for manual focus lenses capinbuck Pentax SLR Lens Discussion 8 02-15-2007 06:11 PM
All times are GMT -7. The time now is 10:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
